주요 콘텐츠로 건너뛰기
Nvidia Shield Controller Buttons Replacement
필요한 것
  1. Nvidia Shield Controller Buttons Replacement, Remove Front Panel: 1 단계, 이미지 1/3 Nvidia Shield Controller Buttons Replacement, Remove Front Panel: 1 단계, 이미지 2/3 Nvidia Shield Controller Buttons Replacement, Remove Front Panel: 1 단계, 이미지 3/3
    • Remove the seven 6.4mm T5 Torx screws from the back panel.
    • Use the spudger to separate the front and back panels.
  2. Nvidia Shield Controller Buttons Replacement, Remove Green Grill: 2 단계, 이미지 1/2 Nvidia Shield Controller Buttons Replacement, Remove Green Grill: 2 단계, 이미지 2/2
    • The green grill is not screwed in so it can be pulled right out.
  3. Nvidia Shield Controller Buttons Replacement, Remove Battery Cables: 3 단계, 이미지 1/3 Nvidia Shield Controller Buttons Replacement, Remove Battery Cables: 3 단계, 이미지 2/3 Nvidia Shield Controller Buttons Replacement, Remove Battery Cables: 3 단계, 이미지 3/3
    • Remove the six 6.5mm T5 Torx screws.
    • Disconnect the power wires.
    • Peel back the copper tape and disconnect the black and white wires.
  4. Nvidia Shield Controller Buttons Replacement, Remove Battery Apparatus: 4 단계, 이미지 1/1
    • Pull the battery apparatus out once all cables are removed.
  5. Nvidia Shield Controller Buttons Replacement, Removing Button Board: 5 단계, 이미지 1/3 Nvidia Shield Controller Buttons Replacement, Removing Button Board: 5 단계, 이미지 2/3 Nvidia Shield Controller Buttons Replacement, Removing Button Board: 5 단계, 이미지 3/3
    • Remove seven 6.5 mm T5 torx screws from the button board.
    • Refer to the second image as some screws are not visible in the first image. One of these screws is covered by the orange ribbon.
    • Remove the button board.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Daniel Eberhart
회원 가입일: 09/22/14
379 평판
안내서 1개 작성함
USF Tampa, Team 1-1, Hickman Fall 2014 USF Tampa, Team 1-1, Hickman Fall 2014 회원
USFT-HICKMAN-F14S1G1
4 회원들
안내서 18개 작성하였습니다
댓글 2개
From where can I get the buttons?
Chirag Khatri - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 27
전체 시간: 6,059
