주요 콘텐츠로 건너뛰기
Nvidia Shield Fan Replacement
필요한 것
  1. Nvidia Shield Fan Replacement, Remove Front Panel: 1 단계, 이미지 1/3 Nvidia Shield Fan Replacement, Remove Front Panel: 1 단계, 이미지 2/3 Nvidia Shield Fan Replacement, Remove Front Panel: 1 단계, 이미지 3/3
    • Remove the seven 6.4mm T5 Torx screws from the back panel.
    • Use the spudger to separate the front and back panels.
  2. Nvidia Shield Fan Replacement, Remove Green Grill: 2 단계, 이미지 1/2 Nvidia Shield Fan Replacement, Remove Green Grill: 2 단계, 이미지 2/2
    • The green grill is not screwed in so it can be pulled right out.
  3. Nvidia Shield Fan Replacement, Remove Battery Cables: 3 단계, 이미지 1/3 Nvidia Shield Fan Replacement, Remove Battery Cables: 3 단계, 이미지 2/3 Nvidia Shield Fan Replacement, Remove Battery Cables: 3 단계, 이미지 3/3
    • Remove the six 6.5mm T5 Torx screws.
    • Disconnect the power wires.
    • Peel back the copper tape and disconnect the black and white wires.
  4. Nvidia Shield Fan Replacement, Remove Battery Apparatus: 4 단계, 이미지 1/1
    • Pull the battery apparatus out once all cables are removed.
  5. Nvidia Shield Fan Replacement, Removing Fan: 5 단계, 이미지 1/3 Nvidia Shield Fan Replacement, Removing Fan: 5 단계, 이미지 2/3 Nvidia Shield Fan Replacement, Removing Fan: 5 단계, 이미지 3/3
    • Cooling is important for electronics, the last thing they want is to overheat.
    • Remove the two 7.3mm and four 8.4mm T5 Torx screws and disconnect the power cable.
    • Lift the fan free after the screws and cable are removed.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Marc Perez
회원 가입일: 09/29/14
545 평판
안내서 2개 작성하였습니다
USF Tampa, Team 1-1, Hickman Fall 2014 USF Tampa, Team 1-1, Hickman Fall 2014 회원
USFT-HICKMAN-F14S1G1
4 회원들
안내서 18개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 9
30일 전: 33
전체 시간: 2,891
