주요 콘텐츠로 건너뛰기
Nvidia Shield Joystick Replacement
필요한 것
  1. Nvidia Shield Joystick Replacement, Remove Front Panel: 1 단계, 이미지 1/3 Nvidia Shield Joystick Replacement, Remove Front Panel: 1 단계, 이미지 2/3 Nvidia Shield Joystick Replacement, Remove Front Panel: 1 단계, 이미지 3/3
    • Remove the seven 6.4mm T5 Torx screws from the back panel.
    • Use the spudger to separate the front and back panels.
  2. Nvidia Shield Joystick Replacement, Remove Green Grill: 2 단계, 이미지 1/2 Nvidia Shield Joystick Replacement, Remove Green Grill: 2 단계, 이미지 2/2
    • The green grill is not screwed in so it can be pulled right out.
  3. Nvidia Shield Joystick Replacement, Remove Battery Cables: 3 단계, 이미지 1/3 Nvidia Shield Joystick Replacement, Remove Battery Cables: 3 단계, 이미지 2/3 Nvidia Shield Joystick Replacement, Remove Battery Cables: 3 단계, 이미지 3/3
    • Remove the six 6.5mm T5 Torx screws.
    • Disconnect the power wires.
    • Peel back the copper tape and disconnect the black and white wires.
  4. Nvidia Shield Joystick Replacement, Remove Battery Apparatus: 4 단계, 이미지 1/1
    • Pull the battery apparatus out once all cables are removed.
  5. Nvidia Shield Joystick Replacement, Removing Fan: 5 단계, 이미지 1/3 Nvidia Shield Joystick Replacement, Removing Fan: 5 단계, 이미지 2/3 Nvidia Shield Joystick Replacement, Removing Fan: 5 단계, 이미지 3/3
    • Cooling is important for electronics, the last thing they want is to overheat.
    • Remove the two 7.3mm and four 8.4mm T5 Torx screws and disconnect the power cable.
    • Lift the fan free after the screws and cable are removed.
  6. Nvidia Shield Joystick Replacement, Removing Logic Board: 6 단계, 이미지 1/3 Nvidia Shield Joystick Replacement, Removing Logic Board: 6 단계, 이미지 2/3 Nvidia Shield Joystick Replacement, Removing Logic Board: 6 단계, 이미지 3/3
    • The large board under the back case is the motherboard.
    • Using your T5 Torx screwdriver, remove six screws from the motherboard—two 7.3 mm screws and four 8.4 mm screws.
    • Simply pull gently on the edges of the board, wiggling it if necessary so as not to damage the ports at the top of the board.
  7. Nvidia Shield Joystick Replacement, Removing Joysticks: 7 단계, 이미지 1/3 Nvidia Shield Joystick Replacement, Removing Joysticks: 7 단계, 이미지 2/3 Nvidia Shield Joystick Replacement, Removing Joysticks: 7 단계, 이미지 3/3
    • Unscrew the 3 6.5mm screws from the Joystick board
    • Unplug the ribbon attached on the right hand side of the board
    • Once removed, the Joystick board will lift from the panel, allowing replacement
    • The thumb-Sticks can be pulled off of the metal pegs for replacement.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Andrew Barbanera
회원 가입일: 09/20/14
376 평판
안내서 2개 작성하였습니다
USF Tampa, Team 1-1, Hickman Fall 2014 USF Tampa, Team 1-1, Hickman Fall 2014 회원
USFT-HICKMAN-F14S1G1
4 회원들
안내서 18개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 7
30일 전: 35
전체 시간: 3,791
