주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nvidia Shield Pro Android TV Controller Motherboard Replacement
필요한 것
  1. Nvidia Shield Pro Android TV Controller Motherboard Replacement, Thumbsticks: 1 단계, 이미지 3개 중 1개 Nvidia Shield Pro Android TV Controller Motherboard Replacement, Thumbsticks: 1 단계, 이미지 3개 중 2개 Nvidia Shield Pro Android TV Controller Motherboard Replacement, Thumbsticks: 1 단계, 이미지 3개 중 3개
    • Remove the six T6 Torx screws from the back of the controller.
  2. Nvidia Shield Pro Android TV Controller Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Gently pry open the top frame of the cover with a plastic opening tool.
  3. Nvidia Shield Pro Android TV Controller Motherboard Replacement: 3 단계, 이미지 2개 중 1개 Nvidia Shield Pro Android TV Controller Motherboard Replacement: 3 단계, 이미지 2개 중 2개
    • Gently pull the wire connector directly out of its socket, separating the two halves of the controller.
  4. Nvidia Shield Pro Android TV Controller Motherboard Replacement: 4 단계, 이미지 2개 중 1개 Nvidia Shield Pro Android TV Controller Motherboard Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the two T6 Torx screws.
  5. Nvidia Shield Pro Android TV Controller Motherboard Replacement: 5 단계, 이미지 2개 중 1개 Nvidia Shield Pro Android TV Controller Motherboard Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the guard piece that secures the thumb-sticks to the controller.
    • Apply vertical pressure with two fingers to carefully pop off the thumb-stick(s) in need of repair.
    • Replace it by sliding a new thumb-stick onto the plastic post that secured the old one.
  6. Nvidia Shield Pro Android TV Controller Motherboard Replacement, Triggers: 6 단계, 이미지 3개 중 1개 Nvidia Shield Pro Android TV Controller Motherboard Replacement, Triggers: 6 단계, 이미지 3개 중 2개 Nvidia Shield Pro Android TV Controller Motherboard Replacement, Triggers: 6 단계, 이미지 3개 중 3개
    • Use a Torx T6 screwdriver to remove the two 7 mm screws from the triggers (one on each trigger).
    • Use a Torx T5 screwdriver to remove the two 5 mm screws securing the motherboard.
    • Gently lift the motherboard from the controller housing.
  7. Nvidia Shield Pro Android TV Controller Motherboard Replacement: 7 단계, 이미지 3개 중 1개 Nvidia Shield Pro Android TV Controller Motherboard Replacement: 7 단계, 이미지 3개 중 2개 Nvidia Shield Pro Android TV Controller Motherboard Replacement: 7 단계, 이미지 3개 중 3개
    • Use a Torx T5 screwdriver to remove the two 5 mm screws from the motherboard.
    • Carefully pull the trigger directly out of its socket.
  8. Nvidia Shield Pro Android TV Controller Motherboard Replacement, Controller Motherboard: 8 단계, 이미지 1개 중 1개
    • After removing the triggers, your motherboard is completely separate and ready to be replaced.
결론
Your motherboard is ready to be replaced.
작성자
2다른 기여자 명과 함께
Aidan Shelton
회원 가입일: 02/11/22
73 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 25
전체 시간: 547
