주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nvidia Shield Pro Android TV Controller Rumble Motor Replacement
필요한 것
  1. Nvidia Shield Pro Android TV Controller Rumble Motor Replacement, Thumbsticks: 1 단계, 이미지 3개 중 1개 Nvidia Shield Pro Android TV Controller Rumble Motor Replacement, Thumbsticks: 1 단계, 이미지 3개 중 2개 Nvidia Shield Pro Android TV Controller Rumble Motor Replacement, Thumbsticks: 1 단계, 이미지 3개 중 3개
    • Remove the six T6 Torx screws from the back of the controller.
  2. Nvidia Shield Pro Android TV Controller Rumble Motor Replacement: 2 단계, 이미지 1개 중 1개
    • Gently pry open the top frame of the cover with a plastic opening tool.
  3. Nvidia Shield Pro Android TV Controller Rumble Motor Replacement: 3 단계, 이미지 2개 중 1개 Nvidia Shield Pro Android TV Controller Rumble Motor Replacement: 3 단계, 이미지 2개 중 2개
    • Gently pull the wire connector directly out of its socket, separating the two halves of the controller.
  4. Nvidia Shield Pro Android TV Controller Rumble Motor Replacement: 4 단계, 이미지 2개 중 1개 Nvidia Shield Pro Android TV Controller Rumble Motor Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the two T6 Torx screws.
  5. Nvidia Shield Pro Android TV Controller Rumble Motor Replacement: 5 단계, 이미지 2개 중 1개 Nvidia Shield Pro Android TV Controller Rumble Motor Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the guard piece that secures the thumb-sticks to the controller.
    • Apply vertical pressure with two fingers to carefully pop off the thumb-stick(s) in need of repair.
    • Replace it by sliding a new thumb-stick onto the plastic post that secured the old one.
  6. Nvidia Shield Pro Android TV Controller Rumble Motor Replacement, Rumble Motors: 6 단계, 이미지 3개 중 1개 Nvidia Shield Pro Android TV Controller Rumble Motor Replacement, Rumble Motors: 6 단계, 이미지 3개 중 2개 Nvidia Shield Pro Android TV Controller Rumble Motor Replacement, Rumble Motors: 6 단계, 이미지 3개 중 3개
    • Grip the plugs as close to their ports as possible and pull them directly up and out.
    • Lift the rumble motors up and out of the chassis.
결론
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 6
전체 시간: 291
