주요 콘텐츠로 건너뛰기
Nvidia Shield Pro Android TV Controller Thumbsticks Replacement
필요한 것
  1. Nvidia Shield Pro Android TV Controller Thumbsticks Replacement, Bluetooth Controller Thumbsticks: 1 단계, 이미지 1/3 Nvidia Shield Pro Android TV Controller Thumbsticks Replacement, Bluetooth Controller Thumbsticks: 1 단계, 이미지 2/3 Nvidia Shield Pro Android TV Controller Thumbsticks Replacement, Bluetooth Controller Thumbsticks: 1 단계, 이미지 3/3
    • Remove the six T6 Torx screws from the back of the controller.
  2. Nvidia Shield Pro Android TV Controller Thumbsticks Replacement: 2 단계, 이미지 1/1
    • Gently pry open the top frame of the cover with a plastic opening tool.
  3. Nvidia Shield Pro Android TV Controller Thumbsticks Replacement: 3 단계, 이미지 1/2 Nvidia Shield Pro Android TV Controller Thumbsticks Replacement: 3 단계, 이미지 2/2
    • Gently pull the wire connector directly out of its socket, separating the two halves of the controller.
  4. Nvidia Shield Pro Android TV Controller Thumbsticks Replacement: 4 단계, 이미지 1/2 Nvidia Shield Pro Android TV Controller Thumbsticks Replacement: 4 단계, 이미지 2/2
    • Remove the two T6 Torx screws.
  5. Nvidia Shield Pro Android TV Controller Thumbsticks Replacement: 5 단계, 이미지 1/2 Nvidia Shield Pro Android TV Controller Thumbsticks Replacement: 5 단계, 이미지 2/2
    • Remove the guard piece that secures the thumb-sticks to the controller.
    • Apply vertical pressure with two fingers to carefully pop off the thumb-stick(s) in need of repair.
    • Replace it by sliding a new thumb-stick onto the plastic post that secured the old one.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Ben Carrasco
회원 가입일: 01/23/20
332 평판
안내서 2개 작성하였습니다
Cal Poly, Team S18-G2, White Winter 2020 Cal Poly, Team S18-G2, White Winter 2020 회원
CPSU-WHITE-W20S18G2
4 회원들
안내서 6개 작성하였습니다
댓글 3개
Very good instructions that were very helpful. Do you have recommendations on which thumbsticks are the best since the shield seems to have wider and deeper ones? Thanks again for the guide.
Charles Brodie - 답글
Just wondering where would I be able to buy a thumbstick spare part to replace it.
xguyun - 답글
Thanks, very good post, and it could be very useful for me. Just wondering where would I be able to buy a spare part for this thumbstick to replace my broken one.
xguyun - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 34
전체 시간: 1,635
