주요 콘텐츠로 건너뛰기
Nvidia Shield Pro Android TV Controller Triggers Replacement
필요한 것
  1. Nvidia Shield Pro Android TV Controller Triggers Replacement, Bluetooth Controller Thumbsticks: 1 단계, 이미지 1/3 Nvidia Shield Pro Android TV Controller Triggers Replacement, Bluetooth Controller Thumbsticks: 1 단계, 이미지 2/3 Nvidia Shield Pro Android TV Controller Triggers Replacement, Bluetooth Controller Thumbsticks: 1 단계, 이미지 3/3
    • Remove the six T6 Torx screws from the back of the controller.
  2. Nvidia Shield Pro Android TV Controller Triggers Replacement: 2 단계, 이미지 1/1
    • Gently pry open the top frame of the cover with a plastic opening tool.
  3. Nvidia Shield Pro Android TV Controller Triggers Replacement: 3 단계, 이미지 1/2 Nvidia Shield Pro Android TV Controller Triggers Replacement: 3 단계, 이미지 2/2
    • Gently pull the wire connector directly out of its socket, separating the two halves of the controller.
  4. Nvidia Shield Pro Android TV Controller Triggers Replacement: 4 단계, 이미지 1/2 Nvidia Shield Pro Android TV Controller Triggers Replacement: 4 단계, 이미지 2/2
    • Remove the two T6 Torx screws.
  5. Nvidia Shield Pro Android TV Controller Triggers Replacement: 5 단계, 이미지 1/2 Nvidia Shield Pro Android TV Controller Triggers Replacement: 5 단계, 이미지 2/2
    • Remove the guard piece that secures the thumb-sticks to the controller.
    • Apply vertical pressure with two fingers to carefully pop off the thumb-stick(s) in need of repair.
    • Replace it by sliding a new thumb-stick onto the plastic post that secured the old one.
  6. Nvidia Shield Pro Android TV Controller Triggers Replacement, Triggers: 6 단계, 이미지 1/3 Nvidia Shield Pro Android TV Controller Triggers Replacement, Triggers: 6 단계, 이미지 2/3 Nvidia Shield Pro Android TV Controller Triggers Replacement, Triggers: 6 단계, 이미지 3/3
    • Use a Torx T6 screwdriver to remove the two 7 mm screws from the triggers (one on each trigger).
    • Use a Torx T5 screwdriver to remove the two 5 mm screws securing the motherboard.
    • Gently lift the motherboard from the controller housing.
  7. Nvidia Shield Pro Android TV Controller Triggers Replacement: 7 단계, 이미지 1/3 Nvidia Shield Pro Android TV Controller Triggers Replacement: 7 단계, 이미지 2/3 Nvidia Shield Pro Android TV Controller Triggers Replacement: 7 단계, 이미지 3/3
    • Use a Torx T5 screwdriver to remove the two 5 mm screws from the motherboard.
    • Carefully pull the trigger directly out of its socket.
결론
Jared Campbell
회원 가입일: 02/16/22
85 평판
안내서 1개 작성함
댓글 한 개
how do you put the shoulder buttons back in. They fell out when I was trying to replace the battery
demarko9999 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 22
전체 시간: 276
