주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nvidia Shield Pro Android TV Controller Triggers Replacement
필요한 것
    1. Nvidia Shield Pro Android TV Controller Triggers Replacement, Thumbsticks: 1 단계, 이미지 3개 중 1개 Nvidia Shield Pro Android TV Controller Triggers Replacement, Thumbsticks: 1 단계, 이미지 3개 중 2개 Nvidia Shield Pro Android TV Controller Triggers Replacement, Thumbsticks: 1 단계, 이미지 3개 중 3개
      • Remove the six T6 Torx screws from the back of the controller.
      댓글 쓰기
    2. Nvidia Shield Pro Android TV Controller Triggers Replacement: 2 단계, 이미지 1개 중 1개
      • Gently pry open the top frame of the cover with a plastic opening tool.
      댓글 쓰기
    3. Nvidia Shield Pro Android TV Controller Triggers Replacement: 3 단계, 이미지 2개 중 1개 Nvidia Shield Pro Android TV Controller Triggers Replacement: 3 단계, 이미지 2개 중 2개
      • Gently pull the wire connector directly out of its socket, separating the two halves of the controller.
      댓글 쓰기
    4. Nvidia Shield Pro Android TV Controller Triggers Replacement: 4 단계, 이미지 2개 중 1개 Nvidia Shield Pro Android TV Controller Triggers Replacement: 4 단계, 이미지 2개 중 2개
      • Remove the two T6 Torx screws.
      댓글 쓰기
    5. Nvidia Shield Pro Android TV Controller Triggers Replacement: 5 단계, 이미지 2개 중 1개 Nvidia Shield Pro Android TV Controller Triggers Replacement: 5 단계, 이미지 2개 중 2개
      • Remove the guard piece that secures the thumb-sticks to the controller.
      • Apply vertical pressure with two fingers to carefully pop off the thumb-stick(s) in need of repair.
      • Replace it by sliding a new thumb-stick onto the plastic post that secured the old one.
      댓글 쓰기
    1. Nvidia Shield Pro Android TV Controller Triggers Replacement, Triggers: 6 단계, 이미지 3개 중 1개 Nvidia Shield Pro Android TV Controller Triggers Replacement, Triggers: 6 단계, 이미지 3개 중 2개 Nvidia Shield Pro Android TV Controller Triggers Replacement, Triggers: 6 단계, 이미지 3개 중 3개
      • Use a Torx T6 screwdriver to remove the two 7 mm screws from the triggers (one on each trigger).
      • Use a Torx T5 screwdriver to remove the two 5 mm screws securing the motherboard.
      • Gently lift the motherboard from the controller housing.
      댓글 쓰기
    2. Nvidia Shield Pro Android TV Controller Triggers Replacement: 7 단계, 이미지 3개 중 1개 Nvidia Shield Pro Android TV Controller Triggers Replacement: 7 단계, 이미지 3개 중 2개 Nvidia Shield Pro Android TV Controller Triggers Replacement: 7 단계, 이미지 3개 중 3개
      • Use a Torx T5 screwdriver to remove the two 5 mm screws from the motherboard.
      • Carefully pull the trigger directly out of its socket.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Jared Campbell
회원 가입일: 02/16/22
85 평판
안내서 1개를 작성함
2가이드 댓글
how do you put the shoulder buttons back in. They fell out when I was trying to replace the battery
demarko9999 - 답글 공유
Where do you buy parts? My RB broke and I'm trying to find where to buy a replacement part, but can't find anywhere.
Christian Borg Xuereb - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 12
지난 30일: 53
전체 시간: 809
