주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nvidia Shield Pro Android TV Hard Drive Replacement
필요한 것
  1. Nvidia Shield Pro Android TV Hard Drive Replacement, Bottom Cover: 1 단계, 이미지 2개 중 1개 Nvidia Shield Pro Android TV Hard Drive Replacement, Bottom Cover: 1 단계, 이미지 2개 중 2개
    • Flip to the back side of your Nvidia Shield Pro Android TV.
    • To open the bottom cover of the Nvidia Shield, start from the corner and slide your plastic opening tool across the gap.
    • If using a plastic opening tool to open the bottom cover is difficult, try using a metal spudger.
  2. Nvidia Shield Pro Android TV Hard Drive Replacement, Hard Drive: 2 단계, 이미지 3개 중 1개 Nvidia Shield Pro Android TV Hard Drive Replacement, Hard Drive: 2 단계, 이미지 3개 중 2개 Nvidia Shield Pro Android TV Hard Drive Replacement, Hard Drive: 2 단계, 이미지 3개 중 3개
    • Remove the two pieces of adhesives found at the top and the bottom side of the hard drive.
    • Put the two adhesives aside. Make sure to keep them flat so that you can put them back on after.
  3. Nvidia Shield Pro Android TV Hard Drive Replacement: 3 단계, 이미지 3개 중 1개 Nvidia Shield Pro Android TV Hard Drive Replacement: 3 단계, 이미지 3개 중 2개 Nvidia Shield Pro Android TV Hard Drive Replacement: 3 단계, 이미지 3개 중 3개
    • Detach the pack of wires by pulling it away from the socket.
  4. Nvidia Shield Pro Android TV Hard Drive Replacement: 4 단계, 이미지 3개 중 1개 Nvidia Shield Pro Android TV Hard Drive Replacement: 4 단계, 이미지 3개 중 2개 Nvidia Shield Pro Android TV Hard Drive Replacement: 4 단계, 이미지 3개 중 3개
    • Next to the empty socket where the black wires were attached to the I/O board (refer back to Step 2), detach the plastic strap from the I/O board by pushing the strap away from the socket using your finger.
  5. Nvidia Shield Pro Android TV Hard Drive Replacement: 5 단계, 이미지 2개 중 1개 Nvidia Shield Pro Android TV Hard Drive Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the screw on the metal piece using a T6 Torx screwdriver and put away the metal piece after removing the screw.
  6. Nvidia Shield Pro Android TV Hard Drive Replacement: 6 단계, 이미지 1개 중 1개
    • Gently pull the hard drive out of the device.
결론
다른 6명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Jimmy Chen
회원 가입일: 01/23/20
735 평판
안내서 3개를 작성함
Cal Poly, Team S18-G2, White Winter 2020 Cal Poly, Team S18-G2, White Winter 2020 회원
CPSU-WHITE-W20S18G2
4 회원들
안내서 14개를 작성함
5가이드 댓글
The problem with this, is after replacing the Malfunctioning or Corrupted drive that will not solve the problem.
The device still will not run if there’s no Software or Firmware installed onto the new drive.
Can iFixit include that procedure of getting the new drive running.
Because you cannot clone a corrupt or bad drive .
Dennis Teague - 답글 공유
You took the words right out of my mouth. I have read the Nvidia website on how to do this but some of it is over my head. We need a flash for dummies to make sure we do it correctly!
Larry - 공유
ok and now what??? nothing happens… there is no image on the new disk… how do i get it to boot? just stays on green light with no image on screen no boot
John Feathers - 답글 공유
I agree with John, please describe how to flash the image on the new drive.
Mario Martinez - 답글 공유
Hello everyone,
Since its an android device, steps are similar in flashing an android phone.
I found this, hope it helps!
steps:
https://developer.download.nvidia.com/as...
images:
https://developer.nvidia.com/shield-deve...
ContactLeft - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 30
지난 30일: 118
전체 시간: 8,594
