주요 콘텐츠로 건너뛰기
Nvidia Shield Pro Android TV Motherboard Replacement
필요한 것
  1. Nvidia Shield Pro Android TV Motherboard Replacement, Motherboard: 1 단계, 이미지 1/3 Nvidia Shield Pro Android TV Motherboard Replacement, Motherboard: 1 단계, 이미지 2/3 Nvidia Shield Pro Android TV Motherboard Replacement, Motherboard: 1 단계, 이미지 3/3
    • Use a plastic opening tool to pry open the front panel.
  2. Nvidia Shield Pro Android TV Motherboard Replacement: 2 단계, 이미지 1/3 Nvidia Shield Pro Android TV Motherboard Replacement: 2 단계, 이미지 2/3 Nvidia Shield Pro Android TV Motherboard Replacement: 2 단계, 이미지 3/3
    • Use a Torx TR6 screwdriver to remove the five 6mm screws that are securing the fan.
    • Unplug the power supply connected to the fan.
  3. Nvidia Shield Pro Android TV Motherboard Replacement: 3 단계, 이미지 1/2 Nvidia Shield Pro Android TV Motherboard Replacement: 3 단계, 이미지 2/2
    • Unplug the two black cable bundles that are running over the motherboard.
  4. Nvidia Shield Pro Android TV Motherboard Replacement: 4 단계, 이미지 1/3 Nvidia Shield Pro Android TV Motherboard Replacement: 4 단계, 이미지 2/3 Nvidia Shield Pro Android TV Motherboard Replacement: 4 단계, 이미지 3/3
    • Use a Torx TR6 screwdriver to remove the three 5mm screws securing the motherboard.
    • Detach the black and white coaxial cables from the motherboard.
    • Lift the motherboard out of the device and disconnect the black cable bundle.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Nate Hale
회원 가입일: 09/16/20
317 평판
안내서 2개 작성하였습니다
댓글 한 개
Please update the title of this to specify which model year Shield Pro it is for. I was looking for the 2019 model instructions and this obviously isn't that.
Thanks!
jkr4m3r - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 17
30일 전: 61
전체 시간: 2,430
