주요 콘텐츠로 건너뛰기
Nvidia Shield TV 1st Generation Fan/Heat Sink Replacement
필요한 것
  1. Nvidia Shield TV 1st Generation Fan/Heat Sink Replacement, Fan/Heat Sink: 1 단계, 이미지 1/1
    • Flip the device over and use a plastic opening tool to remove the bottom cover.
  2. Nvidia Shield TV 1st Generation Fan/Heat Sink Replacement: 2 단계, 이미지 1/2 Nvidia Shield TV 1st Generation Fan/Heat Sink Replacement: 2 단계, 이미지 2/2
    • Remove the five screws using T6 Torx screwdriver.
  3. Nvidia Shield TV 1st Generation Fan/Heat Sink Replacement: 3 단계, 이미지 1/2 Nvidia Shield TV 1st Generation Fan/Heat Sink Replacement: 3 단계, 이미지 2/2
    • Remove the power supply cord.
  4. Nvidia Shield TV 1st Generation Fan/Heat Sink Replacement: 4 단계, 이미지 1/1
    • Gently pull the fan away from the edge of the device.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Joshua Neally
회원 가입일: 09/25/17
581 평판
안내서 4개 작성하였습니다
USF Tampa, Team S16-G6, Eyestone Fall 2017 USF Tampa, Team S16-G6, Eyestone Fall 2017 회원
USFT-EYESTONE-F17S16G6
3 회원들
안내서 7개 작성하였습니다
댓글 2개
So can you clean the fan & heatsink with out having to buy spare parts. Thanks.
bigall - 답글
Or blindly buy a new one :D
Florian Valvatte -
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 9
30일 전: 79
전체 시간: 7,260
