소개
The heat sink will need to be replaced if your device consistently becomes very hot. Before removing the heat sink, make sure the device is turned off and is cool. When removing the component, make sure to be careful, as the parts are delicate and can break or chip easily.
필요한 것
Flip the device over and use a plastic opening tool to remove the bottom cover.
다른 4명이 해당 안내서를 완성하였습니다.
댓글 2개
Or blindly buy a new one :D
