소개
The hard drive can be replaced if the user wants to upgrade with a hard drive with more memory. It will also need to be replaced if the memory in the current hard drive becomes corrupted.
필요한 것
Flip the device over and use a plastic opening tool to remove the bottom cover.
다른 5명이 해당 안내서를 완성하였습니다.
댓글 7개
This guide completely skips over the details on how to disconnect the cables. This is by far the trickiest part of this operation. The fact that the commenter above tore his SATA cable is proof that crucial steps of this procedure are missing!
ctphillips - 답글
How on earth do you disconnect the flat SATA cable from the motherboard safely?
