주요 콘텐츠로 건너뛰기
Nvidia Shield TV 1st Generation I/O Board Replacement
필요한 것
  1. Nvidia Shield TV 1st Generation I/O Board Replacement, I/O Board: 1 단계, 이미지 1/1
    • Flip the device over and use a plastic opening tool to remove the bottom cover.
  2. Nvidia Shield TV 1st Generation I/O Board Replacement: 2 단계, 이미지 1/2 Nvidia Shield TV 1st Generation I/O Board Replacement: 2 단계, 이미지 2/2
    • Remove the indicated cables and ribbon wires.
  3. Nvidia Shield TV 1st Generation I/O Board Replacement: 3 단계, 이미지 1/2 Nvidia Shield TV 1st Generation I/O Board Replacement: 3 단계, 이미지 2/2
    • Remove the indicated four screws using the T6 Torx screwdriver.
  4. Nvidia Shield TV 1st Generation I/O Board Replacement: 4 단계, 이미지 1/1
    • Carefully tilt and pull out the I/O board from the device.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Joshua Neally
회원 가입일: 09/25/17
581 평판
안내서 4개 작성하였습니다
USF Tampa, Team S16-G6, Eyestone Fall 2017 USF Tampa, Team S16-G6, Eyestone Fall 2017 회원
USFT-EYESTONE-F17S16G6
3 회원들
안내서 7개 작성하였습니다
댓글 4개
where do i get a new I/O Board ?
Max Eschbach (SAVAGE) - 답글
Yaaa, where can we get the I/O board? :-D
VashCZ - 답글
Yes, i need a replacement I/O board too, where can I find one?
Anand Dhungav - 답글
Where can I get a replacement I/O board? What good are instructions without any availability for parts?
Mike - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 21
전체 시간: 3,866
