주요 콘텐츠로 건너뛰기
Nvidia Shield Tablet K1 Back Panel Replacement
필요한 것
  1. Nvidia Shield Tablet K1 Back Panel Replacement, Back Panel: 1 단계, 이미지 1/1
    • Starting at the Micro SD Card Slot and using the blue plastic opening tool, begin to maneuver the tool around the edges while applying light pressure to lift the panel upwards.
  2. Nvidia Shield Tablet K1 Back Panel Replacement: 2 단계, 이미지 1/2 Nvidia Shield Tablet K1 Back Panel Replacement: 2 단계, 이미지 2/2
    • There are clips holding the back panel to the rest of the case. You must apply some force to lift the back panel off.
    • Continue lifting up the panel all the way around the edges of the tablet.
    • Once all of the panel clips are unfastened, gently remove the back panel.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Ryan Butler
회원 가입일: 02/09/16
1,695 평판
안내서 9개 작성하였습니다
iFixit, Team 1-1, Weber Winter 2016 iFixit, Team 1-1, Weber Winter 2016 회원
FIX-WEBER-W16S1G1
4 회원들
안내서 37개 작성하였습니다
댓글 2개
Hello, I’m planning on replacing the battery on my K1 soon, will the rear panel snap back in?
Scott - 답글
but wait theres flex cable your not showing thats attached to the cover it could be ripped off and bricked like mine because no one know the name of said cable
Christian Rogers - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 11
30일 전: 23
전체 시간: 4,928
