주요 콘텐츠로 건너뛰기
Nvidia Shield Tablet K1 Battery Replacement
필요한 것
  1. Nvidia Shield Tablet K1 Battery Replacement, Back Panel: 1 단계, 이미지 1/1
    • Starting at the Micro SD Card Slot and using the blue plastic opening tool, begin to maneuver the tool around the edges while applying light pressure to lift the panel upwards.
  2. Nvidia Shield Tablet K1 Battery Replacement: 2 단계, 이미지 1/2 Nvidia Shield Tablet K1 Battery Replacement: 2 단계, 이미지 2/2
    • There are clips holding the back panel to the rest of the case. You must apply some force to lift the back panel off.
    • Continue lifting up the panel all the way around the edges of the tablet.
    • Once all of the panel clips are unfastened, gently remove the back panel.
  3. Nvidia Shield Tablet K1 Battery Replacement, Battery: 3 단계, 이미지 1/2 Nvidia Shield Tablet K1 Battery Replacement, Battery: 3 단계, 이미지 2/2
    • The battery is heavily glued down so you will need to apply force while also exercising caution to not damage the rest of the device.
    • Using the blue plastic opening tool, place the lip of the tool underneath the battery as seen in the photo.
  4. Nvidia Shield Tablet K1 Battery Replacement: 4 단계, 이미지 1/3 Nvidia Shield Tablet K1 Battery Replacement: 4 단계, 이미지 2/3 Nvidia Shield Tablet K1 Battery Replacement: 4 단계, 이미지 3/3
    • Once you have the blue plastic opening tool underneath the battery, work the tool around the edges of the battery similar to the technique used for the back panel.
  5. Nvidia Shield Tablet K1 Battery Replacement: 5 단계, 이미지 1/1
    • When the battery seems loose enough, use the blue plastic opening tool to lift the battery from the device.
    • The battery has four wires connecting it to the device. Be careful not to damage these wires while removing the battery.
  6. Nvidia Shield Tablet K1 Battery Replacement: 6 단계, 이미지 1/3 Nvidia Shield Tablet K1 Battery Replacement: 6 단계, 이미지 2/3 Nvidia Shield Tablet K1 Battery Replacement: 6 단계, 이미지 3/3
    • The wires to the battery are soldered to the motherboard. You may also check the soldering techniques guide for additional tips on soldering.
    • If your device's wiring doesn't exactly match these photos, snap a picture or make a note of what color wire goes to which contact on the motherboard before you detach them. (A mis-wired battery could cause electrical shorts and ruin the tablet for good.)
    • Using a soldering iron, desolder the four wires from the motherboard.
    • Once the wires are free from the motherboard, your battery should be free to remove from your device.
결론
다른 15명이 해당 안내서를 완성하였습니다.
James Upchurch
회원 가입일: 02/09/16
658 평판
안내서 3개 작성하였습니다
USF Tampa, Team 7-7, Cagle Spring 2016 USF Tampa, Team 7-7, Cagle Spring 2016 회원
USFT-CAGLE-S16S7G7
3 회원들
안내서 9개 작성하였습니다
댓글 7개
Hello! Can anyone suggest a specific battery for K1 model ? Also the new battery comes with it's own wires as it is shown on Step5 ?
Hablando - 답글
Quelqu'un peut-il proposer une batterie spécifique pour le modèle K1 s'il vous plait ?
Tony 06 - 답글
Cannot find a replacement battery anywhere, any information would be appreciated.
Thanks!
Carl
cgarrand1 - 답글
Here: to aliexpress
I just happened to be looking because my battery life is atrocious. And here's the forum where I found it. They have other links too if you want to try them out.
XDA dev
Nathaniel Phillips -
I just happened to be looking into this myself. I found a forum with many links that can be found by searching “Finding Replacement Battery in 2017?” . The thread is on XDA-developers.com. This is a link that works: on de.aliexpress.com
Good luck. As there is no convincing upgrade from the Shield K1, I might do this too. Other people noted that you need the little PCB attached to the original battery to solder it onto the bare replacement battery.
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 39
30일 전: 189
전체 시간: 40,688
