Starting at the Micro SD Card Slot and using the blue plastic opening tool, begin to maneuver the tool around the edges while applying light pressure to lift the panel upwards.
Use the angled tweezers to disconnect the black power cable from the mother board. The Cable should pop up from its slot when pulled.
다른 3명이 해당 안내서를 완성하였습니다.
One Comment
Odd question for you. I'm replacing the antena in a nvidia shield as an experimant, as was wonder if you know what type of connecter is used on the cable to the pcb. I dont want to desoder the exsisting antenna if i can help it as they are calabrated.
