이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
이 단계에 사용된 도구:Anti-Static Wrist Strap$7.95-
Set the tablet so the buttons, microSD, and stylus port are facing you.
Open the microSD slot.
Using the flat end of the spudger tool, carefully pry open the case starting from the microSD slot, slowly sliding the spudger along the inside edge of the case.
As you remove your case, be aware of small clips along the edges.
Finally, set the old casing aside.
Carefully use the precision tweezers to unplug the ribbon cable.
Remove the two 6.5 mm Phillips #00 screws and seven 3.0 mm Phillips #00 screws.
Use a pair of tweezers to disconnect the three black antenna cables from the motherboard.
Use the flat end of the spudger tool to carefully pry up the motherboard.
Desolder the positive and negative battery cables from the motherboard.
The motherboard should now come free.
다른 6명이 해당 안내서를 완성하였습니다.
댓글 9개
Where do you obtain a new motherboard?
The real question is more about how to find a new shield tablet motherboard ??
willixlive - 답글
where can i buy the motherboard
waar kan ik een nieuw shield moederbord kopen?
Hello, I'm looking for a description of the various ribbon connectors on the motherboard.
I'm also looking for a hint to solve a problem I have after replacing the screen+digitizer: the right side (half) of the touch screen does'n work.
