주요 콘텐츠로 건너뛰기
Nvidia Shield Tablet Rear Case Replacement
필요한 것
  1. Nvidia Shield Tablet Rear Case Replacement, Rear Case: 1 단계, 이미지 1/2 Nvidia Shield Tablet Rear Case Replacement, Rear Case: 1 단계, 이미지 2/2
    • First, remove the stylus from your tablet.
  2. Nvidia Shield Tablet Rear Case Replacement: 2 단계, 이미지 1/3 Nvidia Shield Tablet Rear Case Replacement: 2 단계, 이미지 2/3 Nvidia Shield Tablet Rear Case Replacement: 2 단계, 이미지 3/3
    이 단계에 사용된 도구:
    Anti-Static Wrist Strap
    $7.95
    구매
    • Set the tablet so the buttons, microSD, and stylus port are facing you.
    • Open the microSD slot.
    • Using the flat end of the spudger tool, carefully pry open the case starting from the microSD slot, slowly sliding the spudger along the inside edge of the case.
    • You may want to put on your anti-static wrist strap at this point as the motherboard will be vulnerable to physical touch and electrostatic shock after the casing is removed.
  3. Nvidia Shield Tablet Rear Case Replacement: 3 단계, 이미지 1/2 Nvidia Shield Tablet Rear Case Replacement: 3 단계, 이미지 2/2
    • As you remove your case, be aware of small clips along the edges.
    • Finally, set the old casing aside.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Molly Bauer
회원 가입일: 08/27/15
1,424 평판
안내서 6개 작성하였습니다
USF Tampa, Team 2-2, Blackwell Fall 2015 USF Tampa, Team 2-2, Blackwell Fall 2015 회원
USFT-BLACKWELL-F15S2G2
3 회원들
안내서 11개 작성하였습니다
댓글 한 개
I snapped the cable of the dabbler on the rear case coz i didnt know there was one!
Anyone knows where can i get a new one?
damjannedelkovski - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 6
전체 시간: 3,303
