주요 콘텐츠로 건너뛰기
Nvidia Shield Tablet Speaker Replacement
필요한 것
  1. Nvidia Shield Tablet Speaker Replacement, Rear Case: 1 단계, 이미지 1/2 Nvidia Shield Tablet Speaker Replacement, Rear Case: 1 단계, 이미지 2/2
    • First, remove the stylus from your tablet.
  2. Nvidia Shield Tablet Speaker Replacement: 2 단계, 이미지 1/3 Nvidia Shield Tablet Speaker Replacement: 2 단계, 이미지 2/3 Nvidia Shield Tablet Speaker Replacement: 2 단계, 이미지 3/3
    이 단계에 사용된 도구:
    Anti-Static Wrist Strap
    $7.95
    구매
    • Set the tablet so the buttons, microSD, and stylus port are facing you.
    • Open the microSD slot.
    • Using the flat end of the spudger tool, carefully pry open the case starting from the microSD slot, slowly sliding the spudger along the inside edge of the case.
    • You may want to put on your anti-static wrist strap at this point as the motherboard will be vulnerable to physical touch and electrostatic shock after the casing is removed.
  3. Nvidia Shield Tablet Speaker Replacement: 3 단계, 이미지 1/2 Nvidia Shield Tablet Speaker Replacement: 3 단계, 이미지 2/2
    • As you remove your case, be aware of small clips along the edges.
    • Finally, set the old casing aside.
  4. Nvidia Shield Tablet Speaker Replacement, Speaker: 4 단계, 이미지 1/1
    • Orient your tablet so that the top of the tablet is furthest away from you.
    • Locate the top speaker, a black semi-rectangular piece on the top right side of the tablet.
  5. Nvidia Shield Tablet Speaker Replacement: 5 단계, 이미지 1/1
    • Remove the two 3.0 mm Phillips #00 screws securing the speaker.
  6. Nvidia Shield Tablet Speaker Replacement: 6 단계, 이미지 1/3 Nvidia Shield Tablet Speaker Replacement: 6 단계, 이미지 2/3 Nvidia Shield Tablet Speaker Replacement: 6 단계, 이미지 3/3
    • Gently pry the speaker up with the flat end of a spudger.
    • Use a plastic opening tool to peel up the tape covering the speaker wire.
  7. Nvidia Shield Tablet Speaker Replacement: 7 단계, 이미지 1/2 Nvidia Shield Tablet Speaker Replacement: 7 단계, 이미지 2/2
    이 단계에 사용된 도구:
    $7.95
    구매
    • Next, with a gentle but firm grip, pull the audio input ribbon with the precision tweezers.
    • Finally, unplug the power source from your speaker using the precision tweezers.
    • Make sure you are using your anti-static wrist strap.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Molly Bauer
회원 가입일: 08/27/15
1,424 평판
안내서 6개 작성하였습니다
USF Tampa, Team 2-2, Blackwell Fall 2015 USF Tampa, Team 2-2, Blackwell Fall 2015 회원
USFT-BLACKWELL-F15S2G2
3 회원들
안내서 11개 작성하였습니다
댓글 한 개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 2,602
