주요 콘텐츠로 건너뛰기
(Windows) Installing a HP LaserJet Printer using the HP UPD
  1. (Windows) Installing a HP LaserJet Printer using the HP UPD, Research your printer (PCL/PostScript support): 1 단계, 이미지 1/3 (Windows) Installing a HP LaserJet Printer using the HP UPD, Research your printer (PCL/PostScript support): 1 단계, 이미지 2/3 (Windows) Installing a HP LaserJet Printer using the HP UPD, Research your printer (PCL/PostScript support): 1 단계, 이미지 3/3
    • Due to the general nature of this guide, specific languages are not covered. The HP UPD supports PCL6, PCL5 and PostScript.
    • Find out what print languages your printer supports. The LaserJet Pro M401 series supports PCL6, PCL5, and PostScript. However, PCL6 is recommended.
    • If you use USB, plug your printer in.
  2. (Windows) Installing a HP LaserJet Printer using the HP UPD, Download the best HP UPD driver: 2 단계, 이미지 1/2 (Windows) Installing a HP LaserJet Printer using the HP UPD, Download the best HP UPD driver: 2 단계, 이미지 2/2
    • I knew what my printer used in advance. Yours may have minor variations.
    • Once you know what print language(s) your printer supports, download the best one for your printer. The driver can be found on the HP website.
  3. (Windows) Installing a HP LaserJet Printer using the HP UPD, Driver installation (USB): 3 단계, 이미지 1/3 (Windows) Installing a HP LaserJet Printer using the HP UPD, Driver installation (USB): 3 단계, 이미지 2/3 (Windows) Installing a HP LaserJet Printer using the HP UPD, Driver installation (USB): 3 단계, 이미지 3/3
    • This method copies the UPD files onto your computer. If you connect a new printer and don't install the printer-specific driver, this can be used in place of the model specific driver.
    • At the installation screen, select USB mode- Plug and Play.
    • Once you select the mode, pick the options you wish to use. While these settings can be changed, leave it as-is unless you understand what the change does.
    • Click Next and the files will be copied to your computer.
  4. (Windows) Installing a HP LaserJet Printer using the HP UPD, Driver installation (Dynamic mode): 4 단계, 이미지 1/3 (Windows) Installing a HP LaserJet Printer using the HP UPD, Driver installation (Dynamic mode): 4 단계, 이미지 2/3 (Windows) Installing a HP LaserJet Printer using the HP UPD, Driver installation (Dynamic mode): 4 단계, 이미지 3/3
    • This installation method only works with networked printers. USB IS NOT SUPPORTED.
    • After the driver loads, agree to the license.
    • Once you agree to the license, you will be asked which installation mode you want to use. Select Dynamic Mode and click Next.
    • After selecting Dynamic Mode, click Next. The printer driver will be installed, as well as a universal printer.
    • Once the driver is installed, a static IP address is required, as well as manual driver configuration. The printer is configured via IP address with this setup.
  5. (Windows) Installing a HP LaserJet Printer using the HP UPD, Printer configuration (Manual): 5 단계, 이미지 1/3 (Windows) Installing a HP LaserJet Printer using the HP UPD, Printer configuration (Manual): 5 단계, 이미지 2/3 (Windows) Installing a HP LaserJet Printer using the HP UPD, Printer configuration (Manual): 5 단계, 이미지 3/3
    • ITERIM PRE-REVISION NOTE FOR WINDOWS 10/11 USERS: You must use the legacy control panel for this step (and the next step), not the modern "settings" app. Search "Control panel" in the start menu.
    • Manual configuration is required when using the HP UPD to replace a failing legacy driver. HOWEVER, these printers often use "USB_001" or "DOT4" on really old printers and must be setup properly. If "USB_001" fails, your printer is really old and requires "DOT4".
    • Known "DOT4" printers: LaserJet 1012, LaserJet 1200, others of similar age.
    • Find Devices and Printers. The location varies based on what version of Windows you run. Search for Control panel and find Devices and Printers.
    • Click Add a Printer. Select Add a Local printer if your printer uses USB. If networked, select Add a Network, Wireless or Bluetooth printer.
    • Allow your computer to populate the driver list. Find HP and then locate the driver that says HP Universal Printing (PCL6/PCL5/PostScript). Select the driver and click Next.
    • Name your printer, then click Next.
  6. (Windows) Installing a HP LaserJet Printer using the HP UPD, Print a test page: 6 단계, 이미지 1/3 (Windows) Installing a HP LaserJet Printer using the HP UPD, Print a test page: 6 단계, 이미지 2/3 (Windows) Installing a HP LaserJet Printer using the HP UPD, Print a test page: 6 단계, 이미지 3/3
    • After the printer is installed, print a test page to make sure it works. Click Print a test page and make sure it works.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Nick
회원 가입일: 11/10/09
89,092 평판
안내서 50개 작성하였습니다
Master Techs Master Techs 회원
Community
321 회원들
안내서 1,485개 작성하였습니다
댓글 한 개
I bought an HP printer specified by laserjet. I have followed a few steps to install this printer via HP UPD. at first search for the correct driver, then install it first in a USB mode after that in dynamic mode. then set the configuration pf printer and after completing all the steps just print once for a test.
www.facebook.com
jolly stark - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 10
전체 시간: 9,589
