주요 콘텐츠로 건너뛰기
OBSOLETE - How to Remove a stuck game from an Xbox 360
필요한 것
  1. OBSOLETE - How to Remove a stuck game from an Xbox 360, Remove the faceplate: 1 단계, 이미지 3개 중 1개 OBSOLETE - How to Remove a stuck game from an Xbox 360, Remove the faceplate: 1 단계, 이미지 3개 중 2개 OBSOLETE - How to Remove a stuck game from an Xbox 360, Remove the faceplate: 1 단계, 이미지 3개 중 3개
    • Remove the faceplate from the system. Grab a part of the faceplate, and it should come off.
  2. OBSOLETE - How to Remove a stuck game from an Xbox 360, Find the emergency eject hole: 2 단계, 이미지 1개 중 1개
    • With the faceplate off of the 360, find a small hole on the front of the 360 without the faceplate and stick a paperclip in the hole. This will be found under the X relative to the faceplate on the system.
    • The system in the guide does not have this hole. In this example, opening the console is likely the only way to get your game out if the optical drive does not respond.
  3. OBSOLETE - How to Remove a stuck game from an Xbox 360, Replace the faceplate: 3 단계, 이미지 3개 중 1개 OBSOLETE - How to Remove a stuck game from an Xbox 360, Replace the faceplate: 3 단계, 이미지 3개 중 2개 OBSOLETE - How to Remove a stuck game from an Xbox 360, Replace the faceplate: 3 단계, 이미지 3개 중 3개
    • Reinstall the faceplate on the system. To do this, put even pressure on all parts of the faceplate until it is completely flush with the console.
    • If you are in doubt, it may not hurt to run your hand over the faceplate to make sure and do a visual inspection.
결론
다른 19명이 해당 안내서를 완성하였습니다.
작성자
10다른 기여자 명과 함께
Nick
회원 가입일: 11/10/09
93,273 평판
안내서 59개를 작성함
Master Techs Master Techs 회원
Community
327 회원들
안내서 1,697개를 작성함
댓글 2개
will this work for elite 250 gug
duangphetv - 답글
I have my xbox here but in the pictures I think I have a upgraded xbox 360 and it does not have some of the buttons it had on the pictures but I can't find a place to un clip the face of it
Maddy - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 12
전체 시간: 31,645
