필요한 것
Using the Phillips screwdriver, unscrew the 5 size M2 x .4 x 4mm screws underneath the battery.
Turn the bottom half with the keyboard upside down.
Lift the black tab up to free the ribbon cable.
Carefully pull the ribbon cable out from the connector.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 2개
Step #15 is wrong, disconnect the right blue cable instead of the left.
This also works on the XO-1
Lee Greene - 답글
