주요 콘텐츠로 건너뛰기
OLPC XO-1.5 Keyboard and Touchpad Replacement
필요한 것
  1. OLPC XO-1.5 Keyboard and Touchpad Replacement, Battery: 1 단계, 이미지 1/1
    • Place the laptop upside down with the handle away from you.
  2. OLPC XO-1.5 Keyboard and Touchpad Replacement: 2 단계, 이미지 1/1
    • Slide the tabs out, towards the green edges, to show the open lock symbol.
    • The right tab will stay in place, but the left tab must be held in position while you remove the battery.
  3. OLPC XO-1.5 Keyboard and Touchpad Replacement: 3 단계, 이미지 1/3 OLPC XO-1.5 Keyboard and Touchpad Replacement: 3 단계, 이미지 2/3 OLPC XO-1.5 Keyboard and Touchpad Replacement: 3 단계, 이미지 3/3
    • Lift the middle of the battery to remove it.
  4. OLPC XO-1.5 Keyboard and Touchpad Replacement, Screen Portion: 4 단계, 이미지 1/1
    • Using the Phillips screwdriver, unscrew the 5 size M2 x .4 x 4mm screws underneath the battery.
  5. OLPC XO-1.5 Keyboard and Touchpad Replacement: 5 단계, 이미지 1/1
    • Turn the laptop so that the red XO symbol is right side up.
    • Pull off the white plastic panel with your fingers. There will be 4 tabs that hold the white panel in place. It will require moderate force to remove.
    • If you are having difficulty pulling off the white plastic panel, use a spudger.
  6. OLPC XO-1.5 Keyboard and Touchpad Replacement: 6 단계, 이미지 1/1
    • Unscrew the 4 size M2 x .4 x 4mm screws that are connected to the green plastic.
  7. OLPC XO-1.5 Keyboard and Touchpad Replacement: 7 단계, 이미지 1/1
    • Unplug the white connector with black cables on each end on the left of the hinge.
  8. OLPC XO-1.5 Keyboard and Touchpad Replacement: 8 단계, 이미지 1/1
    • Using the Phillips screwdriver, unscrew the 4 size M3 x .5 x 5mm screws holding the metal to the rest of the laptop.
  9. OLPC XO-1.5 Keyboard and Touchpad Replacement: 9 단계, 이미지 1/1
    • Carefully lift the top half that has the screen away from the bottom half.
    • There is still one black cable connecting the two halves. Be sure not to break it.
  10. OLPC XO-1.5 Keyboard and Touchpad Replacement: 10 단계, 이미지 1/2 OLPC XO-1.5 Keyboard and Touchpad Replacement: 10 단계, 이미지 2/2
    • Rotate the laptop 180 degrees so that the XO logo is now upside down.
    • Remove the center part of green handle. Push the white plastic back cover down away from the keyboard and top half. This should separate easily from the rest of the device.
  11. OLPC XO-1.5 Keyboard and Touchpad Replacement: 11 단계, 이미지 1/1
    • Turn the laptop upside down, exposing the bottom inside of the keyboard.
    • This is similar to how the laptop was positioned when removing the battery, except now the white panel is gone.
  12. OLPC XO-1.5 Keyboard and Touchpad Replacement: 12 단계, 이미지 1/1
    • Slide the black cable (the one that holds the two halves together) out of its connector.
  13. OLPC XO-1.5 Keyboard and Touchpad Replacement: 13 단계, 이미지 1/2 OLPC XO-1.5 Keyboard and Touchpad Replacement: 13 단계, 이미지 2/2
    • Separate the screen portion from the rest of the laptop.
  14. OLPC XO-1.5 Keyboard and Touchpad Replacement, Keyboard and Touchpad: 14 단계, 이미지 1/2 OLPC XO-1.5 Keyboard and Touchpad Replacement, Keyboard and Touchpad: 14 단계, 이미지 2/2
    • Turn the bottom half with the keyboard upside down.
    • Lift the black tab up to free the ribbon cable.
    • Carefully pull the ribbon cable out from the connector.
  15. OLPC XO-1.5 Keyboard and Touchpad Replacement: 15 단계, 이미지 1/1
    • Lift up the black tab to free the blue ribbon cable.
    • Slide out the blue ribbon cable.
  16. OLPC XO-1.5 Keyboard and Touchpad Replacement: 16 단계, 이미지 1/1
    • Using a Phillips screwdriver, unscrew the 4 size M2 x .4 x 4mm screws in the corners of the circuit board.
  17. OLPC XO-1.5 Keyboard and Touchpad Replacement: 17 단계, 이미지 1/1
    • Slide the circuit board away from you.
    • Lift the circuit board out of the laptop to remove it.
  18. OLPC XO-1.5 Keyboard and Touchpad Replacement: 18 단계, 이미지 1/3 OLPC XO-1.5 Keyboard and Touchpad Replacement: 18 단계, 이미지 2/3 OLPC XO-1.5 Keyboard and Touchpad Replacement: 18 단계, 이미지 3/3
    • Using the Phillips screwdriver, unscrew the 6 screws (M2 x .4 x 4mm) connected to the green plastic of the laptop.
    • Remove all of the green plastic parts from the laptop.
  19. OLPC XO-1.5 Keyboard and Touchpad Replacement: 19 단계, 이미지 1/3 OLPC XO-1.5 Keyboard and Touchpad Replacement: 19 단계, 이미지 2/3 OLPC XO-1.5 Keyboard and Touchpad Replacement: 19 단계, 이미지 3/3
    • Separate the keyboard from the touchpad. Nothing holds the keyboard and touchpad together, so they should separate easily.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Denzel Moody
회원 가입일: 10/05/12
43 평판
안내서 1개 작성함
Cal Poly, Team 3-19, Amido Fall 2012 Cal Poly, Team 3-19, Amido Fall 2012 회원
CPSU-AMIDO-F12S3G19
6 회원들
안내서 10개 작성하였습니다
댓글 2개
Step #15 is wrong, disconnect the right blue cable instead of the left.
Michael Bateman - 답글
This also works on the XO-1
Lee Greene - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 3
전체 시간: 2,856
