주요 콘텐츠로 건너뛰기
OLPC XO-1.5 Screen Replacement
필요한 것
  1. OLPC XO-1.5 Screen Replacement, Battery: 1 단계, 이미지 1/1
    • Place the laptop upside down with the handle away from you.
  2. OLPC XO-1.5 Screen Replacement: 2 단계, 이미지 1/1
    • Slide the tabs out, towards the green edges, to show the open lock symbol.
    • The right tab will stay in place, but the left tab must be held in position while you remove the battery.
  3. OLPC XO-1.5 Screen Replacement: 3 단계, 이미지 1/3 OLPC XO-1.5 Screen Replacement: 3 단계, 이미지 2/3 OLPC XO-1.5 Screen Replacement: 3 단계, 이미지 3/3
    • Lift the middle of the battery to remove it.
  4. OLPC XO-1.5 Screen Replacement, Screen: 4 단계, 이미지 1/3 OLPC XO-1.5 Screen Replacement, Screen: 4 단계, 이미지 2/3 OLPC XO-1.5 Screen Replacement, Screen: 4 단계, 이미지 3/3
    • Turn the laptop so it is resting on its bottom.
    • Open the laptop by rotating the green wings on the side up, then lifting the top half of the laptop.
    • Rotate the top half of the laptop about 90 degrees.
  5. OLPC XO-1.5 Screen Replacement: 5 단계, 이미지 1/2 OLPC XO-1.5 Screen Replacement: 5 단계, 이미지 2/2
    • Turn the laptop upside down, so you can see the screws on the bottom of the top half.
    • Remove the two 4mm screws with a Phillips #1 screwdriver.
    • Rotate the top half 180 degrees.
  6. OLPC XO-1.5 Screen Replacement: 6 단계, 이미지 1/1
    • Rotate the top of the laptop 90 degrees, so that it is facing you again.
    • Slide the green pieces off the device. They should come off easily.
  7. OLPC XO-1.5 Screen Replacement: 7 단계, 이미지 1/3 OLPC XO-1.5 Screen Replacement: 7 단계, 이미지 2/3 OLPC XO-1.5 Screen Replacement: 7 단계, 이미지 3/3
    • Pull down on the white screen cover. It does not require much force.
    • Remove the screen cover.
    • The game pad on the left sometimes falls during this step.
  8. OLPC XO-1.5 Screen Replacement: 8 단계, 이미지 1/2 OLPC XO-1.5 Screen Replacement: 8 단계, 이미지 2/2
    • Unscrew the four 7.62mm Phillips #1 screws on either side of the screen.
    • The screen is still connected by ribbon cables. You can damage the cables if you remove the screen before disconnecting the cables.
    • Move the screen down a little to expose the ribbon cables.
  9. OLPC XO-1.5 Screen Replacement: 9 단계, 이미지 1/3 OLPC XO-1.5 Screen Replacement: 9 단계, 이미지 2/3 OLPC XO-1.5 Screen Replacement: 9 단계, 이미지 3/3
    • Flip up the tab right under the middle top of the screen.
    • Pull the black ribbon cable out of the socket.
  10. OLPC XO-1.5 Screen Replacement: 10 단계, 이미지 1/2 OLPC XO-1.5 Screen Replacement: 10 단계, 이미지 2/2
    • Flip up the smaller tab under the left side of the screen.
    • Remove the small cable to separate the screen from the rest of the laptop.
    • Gently remove the screen.
결론
Andrew Ferrell
회원 가입일: 10/05/12
27 평판
안내서 1개 작성함
Cal Poly, Team 3-19, Amido Fall 2012 Cal Poly, Team 3-19, Amido Fall 2012 회원
CPSU-AMIDO-F12S3G19
6 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 17
전체 시간: 2,295
