이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
This guide will show you how to access the camera on your OLPC XO 4.0 Touch. The camera records video into your laptop.
필요한 것
Remove the two 4mm Phillips #1 screws underneath the screen on the right-hand side.
Rotate the screen 180° and remove the other two screws.
Remove the four black 4mm screws from the metal cover using a Phillips #1 screwdriver.
Remove the metal cover from the laptop.
Unplug the ribbon cable from the connector on the underside of the motherboard.
Pull the camera away from the motherboard to remove it.
