주요 콘텐츠로 건너뛰기
OLPC XO-4 Touch Keyboard Replacement
필요한 것
  1. OLPC XO-4 Touch Keyboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn the laptop upside-down, with the handle facing away from you.
  2. OLPC XO-4 Touch Keyboard Replacement: 2 단계, 이미지 2개 중 1개 OLPC XO-4 Touch Keyboard Replacement: 2 단계, 이미지 2개 중 2개
    • Pull the lock tabs towards the green outer edges of the laptop.
    • Hold the left lock tab in the unlock position until the battery is completely removed in the next step.
  3. OLPC XO-4 Touch Keyboard Replacement: 3 단계, 이미지 2개 중 1개 OLPC XO-4 Touch Keyboard Replacement: 3 단계, 이미지 2개 중 2개
    • Lift up on the middle of the battery to remove it from the device.
  4. OLPC XO-4 Touch Keyboard Replacement, Keyboard: 4 단계, 이미지 2개 중 1개 OLPC XO-4 Touch Keyboard Replacement, Keyboard: 4 단계, 이미지 2개 중 2개
    • Remove the two 2mm Phillips #1 screws from beneath the battery lock tabs.
  5. OLPC XO-4 Touch Keyboard Replacement: 5 단계, 이미지 3개 중 1개 OLPC XO-4 Touch Keyboard Replacement: 5 단계, 이미지 3개 중 2개 OLPC XO-4 Touch Keyboard Replacement: 5 단계, 이미지 3개 중 3개
    • Flip the laptop over to its normal position.
    • Lift the two antennas on both sides to unlock the screen.
    • Open the laptop.
  6. OLPC XO-4 Touch Keyboard Replacement: 6 단계, 이미지 2개 중 1개 OLPC XO-4 Touch Keyboard Replacement: 6 단계, 이미지 2개 중 2개
    • Be careful not to pull the keyboard too far because there is still a ribbon cable attached to the bottom.
    • Gently lift up on the back of the keyboard.
    • Pull the keyboard up far enough to expose the ribbon cable.
  7. OLPC XO-4 Touch Keyboard Replacement: 7 단계, 이미지 2개 중 1개 OLPC XO-4 Touch Keyboard Replacement: 7 단계, 이미지 2개 중 2개
    • Gently lift up on the black connector to release the ribbon cable.
    • Gently pull the blue plastic tab up and away from the black connector.
    • Remove the keyboard from the laptop.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Michael Kellerman
회원 가입일: 01/24/13
58 평판
안내서 3개를 작성함
Cal Poly, Team 3-30, Amido Winter 2013 Cal Poly, Team 3-30, Amido Winter 2013 회원
CPSU-AMIDO-W13S3G30
3 회원들
안내서 12개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 935
