주요 콘텐츠로 건너뛰기
OLPC XO-4 Touch Screen Frame Replacement
필요한 것
  1. OLPC XO-4 Touch Screen Frame Replacement, Battery: 1 단계, 이미지 1/1
    • Turn the laptop upside-down, with the handle facing away from you.
  2. OLPC XO-4 Touch Screen Frame Replacement: 2 단계, 이미지 1/2 OLPC XO-4 Touch Screen Frame Replacement: 2 단계, 이미지 2/2
    • Pull the lock tabs towards the green outer edges of the laptop.
    • Hold the left lock tab in the unlock position until the battery is completely removed in the next step.
  3. OLPC XO-4 Touch Screen Frame Replacement: 3 단계, 이미지 1/2 OLPC XO-4 Touch Screen Frame Replacement: 3 단계, 이미지 2/2
    • Lift up on the middle of the battery to remove it from the device.
  4. OLPC XO-4 Touch Screen Frame Replacement, Screen Frame: 4 단계, 이미지 1/3 OLPC XO-4 Touch Screen Frame Replacement, Screen Frame: 4 단계, 이미지 2/3 OLPC XO-4 Touch Screen Frame Replacement, Screen Frame: 4 단계, 이미지 3/3
    • Remove the two 4mm Phillips #1 screws underneath the screen on the right-hand side.
    • Rotate the screen 180° and remove the other two screws.
    • You will have to put your screwdriver through the handle in order to reach the middle screw for both sides.
  5. OLPC XO-4 Touch Screen Frame Replacement: 5 단계, 이미지 1/3 OLPC XO-4 Touch Screen Frame Replacement: 5 단계, 이미지 2/3 OLPC XO-4 Touch Screen Frame Replacement: 5 단계, 이미지 3/3
    • Remove the green side panel by pressing down on the small green button on the top and sliding the panel up.
    • Repeat the step above for the panel on the other side.
  6. OLPC XO-4 Touch Screen Frame Replacement: 6 단계, 이미지 1/1
    • Be careful not to pull the bottom too far out because a ribbon cable is under the frame and can easily break.
    • Gently lift up the lower part of the frame and pull it down to free the screen frame.
  7. OLPC XO-4 Touch Screen Frame Replacement: 7 단계, 이미지 1/2 OLPC XO-4 Touch Screen Frame Replacement: 7 단계, 이미지 2/2
    • Lift the black connector and pull the ribbon cable out by the purple tab, freeing the frame.
결론
Ji Kim
회원 가입일: 01/25/13
18 평판
안내서 3개 작성하였습니다
Cal Poly, Team 3-29, Amido Winter 2013 Cal Poly, Team 3-29, Amido Winter 2013 회원
CPSU-AMIDO-W13S3G29
4 회원들
안내서 20개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 212
