주요 콘텐츠로 건너뛰기
OLPC XO-4 Touch Wireless Card Replacement
필요한 것
  1. OLPC XO-4 Touch Wireless Card Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn the laptop upside-down, with the handle facing away from you.
  2. OLPC XO-4 Touch Wireless Card Replacement: 2 단계, 이미지 2개 중 1개 OLPC XO-4 Touch Wireless Card Replacement: 2 단계, 이미지 2개 중 2개
    • Pull the lock tabs towards the green outer edges of the laptop.
    • Hold the left lock tab in the unlock position until the battery is completely removed in the next step.
  3. OLPC XO-4 Touch Wireless Card Replacement: 3 단계, 이미지 2개 중 1개 OLPC XO-4 Touch Wireless Card Replacement: 3 단계, 이미지 2개 중 2개
    • Lift up on the middle of the battery to remove it from the device.
  4. OLPC XO-4 Touch Wireless Card Replacement, Screen Frame: 4 단계, 이미지 3개 중 1개 OLPC XO-4 Touch Wireless Card Replacement, Screen Frame: 4 단계, 이미지 3개 중 2개 OLPC XO-4 Touch Wireless Card Replacement, Screen Frame: 4 단계, 이미지 3개 중 3개
    • Remove the two 4mm Phillips #1 screws underneath the screen on the right-hand side.
    • Rotate the screen 180° and remove the other two screws.
    • You will have to put your screwdriver through the handle in order to reach the middle screw for both sides.
  5. OLPC XO-4 Touch Wireless Card Replacement: 5 단계, 이미지 3개 중 1개 OLPC XO-4 Touch Wireless Card Replacement: 5 단계, 이미지 3개 중 2개 OLPC XO-4 Touch Wireless Card Replacement: 5 단계, 이미지 3개 중 3개
    • Remove the green side panel by pressing down on the small green button on the top and sliding the panel up.
    • Repeat the step above for the panel on the other side.
  6. OLPC XO-4 Touch Wireless Card Replacement: 6 단계, 이미지 1개 중 1개
    • Be careful not to pull the bottom too far out because a ribbon cable is under the frame and can easily break.
    • Gently lift up the lower part of the frame and pull it down to free the screen frame.
  7. OLPC XO-4 Touch Wireless Card Replacement: 7 단계, 이미지 2개 중 1개 OLPC XO-4 Touch Wireless Card Replacement: 7 단계, 이미지 2개 중 2개
    • Lift the black connector and pull the ribbon cable out by the purple tab, freeing the frame.
  8. OLPC XO-4 Touch Wireless Card Replacement, Screen: 8 단계, 이미지 1개 중 1개
    • Remove the four 7.62mm screws using a Phillips #1 screwdriver.
  9. OLPC XO-4 Touch Wireless Card Replacement: 9 단계, 이미지 2개 중 1개 OLPC XO-4 Touch Wireless Card Replacement: 9 단계, 이미지 2개 중 2개
    • Be careful not to pull the screen out too far. There are two ribbon cables attached to the screen, and they can easily break.
    • Carefully lift the screen out.
  10. OLPC XO-4 Touch Wireless Card Replacement: 10 단계, 이미지 3개 중 1개 OLPC XO-4 Touch Wireless Card Replacement: 10 단계, 이미지 3개 중 2개 OLPC XO-4 Touch Wireless Card Replacement: 10 단계, 이미지 3개 중 3개
    • Notice that the laptop in this picture has been turned 180° with the antennas now below the screen.
    • For each ribbon cable, lift up the black connector and gently pull the ribbon cables out by the plastic tabs.
  11. OLPC XO-4 Touch Wireless Card Replacement: 11 단계, 이미지 1개 중 1개
    • Remove the screen from the laptop.
  12. OLPC XO-4 Touch Wireless Card Replacement, Back Cover: 12 단계, 이미지 1개 중 1개
    • Remove the four 6mm screws using a Phillips #1 screwdriver.
  13. OLPC XO-4 Touch Wireless Card Replacement: 13 단계, 이미지 2개 중 1개 OLPC XO-4 Touch Wireless Card Replacement: 13 단계, 이미지 2개 중 2개
    • Rotate the top half of the laptop so that the back cover is facing you.
    • Pull up the tabs on the lower part of the back cover and pull it down and away from the antennas.
    • Remove the back cover by gently lifting it off of the laptop.
  14. OLPC XO-4 Touch Wireless Card Replacement, Wireless Card: 14 단계, 이미지 3개 중 1개 OLPC XO-4 Touch Wireless Card Replacement, Wireless Card: 14 단계, 이미지 3개 중 2개 OLPC XO-4 Touch Wireless Card Replacement, Wireless Card: 14 단계, 이미지 3개 중 3개
    • When pulling out the connectors, make sure to hold the metal connector instead of the wire.
    • Gently pull out the two antenna connectors by pulling them away from the motherboard.
  15. OLPC XO-4 Touch Wireless Card Replacement: 15 단계, 이미지 1개 중 1개
    • Remove the black 4mm Phillips #1 screw holding the wireless card in.
  16. OLPC XO-4 Touch Wireless Card Replacement: 16 단계, 이미지 2개 중 1개 OLPC XO-4 Touch Wireless Card Replacement: 16 단계, 이미지 2개 중 2개
    • Remove the wireless card from the laptop by gently sliding it out of its socket.
결론
작성자
3다른 기여자 명과 함께
Zach Yasuda
회원 가입일: 01/24/13
173 평판
안내서 2개를 작성함
Cal Poly, Team 3-29, Amido Winter 2013 Cal Poly, Team 3-29, Amido Winter 2013 회원
CPSU-AMIDO-W13S3G29
4 회원들
안내서 20개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 2
전체 시간: 424
