이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
You will learn how to safely and efficiently remove the battery of the Oppo N1 smart phone.
필요한 것
Insert the plastic opening tool into the crevice. The back cover is most easily opened by starting at this location.
Remove the six 4mm long screws holding the motherboard in with the ph0 Phillips head screw driver.
다른 17명이 해당 안내서를 완성하였습니다.
댓글 4개
And where can I find that battery? What is the battery's id number? ebay doesn't show any. Just oppo n1 mini.
Hi bigupbattery.com has them cheapest I've found the number is part no blp557
