주요 콘텐츠로 건너뛰기
OPPO N1 Headphone Jack and Speaker Cover Replacement
필요한 것
  1. OPPO N1 Headphone Jack and Speaker Cover Replacement, Rear Case: 1 단계, 이미지 1/1
    • Insert the plastic opening tool into the crevice. The back cover is most easily opened by starting at this location.
  2. OPPO N1 Headphone Jack and Speaker Cover Replacement: 2 단계, 이미지 1/2 OPPO N1 Headphone Jack and Speaker Cover Replacement: 2 단계, 이미지 2/2
    • In the photo we rotated the phone ninety degrees counterclockwise.
    • Gently slide the plastic opening tool around the edge of the phone to release the back cover from the phone. You may hear some snapping noises as you release the back cover.
    • The rear case should then come free.
  3. OPPO N1 Headphone Jack and Speaker Cover Replacement, Battery: 3 단계, 이미지 1/2 OPPO N1 Headphone Jack and Speaker Cover Replacement, Battery: 3 단계, 이미지 2/2
    • Remove the six 4mm long screws holding the motherboard in with the ph0 Phillips head screw driver.
  4. OPPO N1 Headphone Jack and Speaker Cover Replacement: 4 단계, 이미지 1/1
    • Use the tweezers or your fingers to remove the sliver plates.
  5. OPPO N1 Headphone Jack and Speaker Cover Replacement: 5 단계, 이미지 1/1
    • Remove the black plate with your fingers.
  6. OPPO N1 Headphone Jack and Speaker Cover Replacement: 6 단계, 이미지 1/3 OPPO N1 Headphone Jack and Speaker Cover Replacement: 6 단계, 이미지 2/3 OPPO N1 Headphone Jack and Speaker Cover Replacement: 6 단계, 이미지 3/3
    • Use tweezers or your fingers to pull up the connector tabs.
  7. OPPO N1 Headphone Jack and Speaker Cover Replacement: 7 단계, 이미지 1/2 OPPO N1 Headphone Jack and Speaker Cover Replacement: 7 단계, 이미지 2/2
    • Use the blue opening tool to carefully pry the battery from the sticky tape that attaches it to the device.
  8. OPPO N1 Headphone Jack and Speaker Cover Replacement, Headphone Jack and Speaker Cover: 8 단계, 이미지 1/1
    • Remove the two 4mm long screws using the ph0 Phillips head screw driver.
    • Remove the six 3mm long screws using the ph0 Phillips head screw driver.
  9. OPPO N1 Headphone Jack and Speaker Cover Replacement: 9 단계, 이미지 1/2 OPPO N1 Headphone Jack and Speaker Cover Replacement: 9 단계, 이미지 2/2
    • Use tweezers or your fingers to remove the plastic cover.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Joshua Stone
회원 가입일: 09/26/14
1,064 평판
안내서 5개 작성하였습니다
USF Tampa, Team 13-5, Staggers Fall 2014 USF Tampa, Team 13-5, Staggers Fall 2014 회원
USFT-STAGGERS-F14S13G5
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 1,464
