주요 콘텐츠로 건너뛰기
OPPO N1 Home Button, Volume Buttons and SIM Card Tray Replacement
필요한 것
  1. OPPO N1 Home Button, Volume Buttons and SIM Card Tray Replacement, Rear Case: 1 단계, 이미지 1/1
    • Insert the plastic opening tool into the crevice. The back cover is most easily opened by starting at this location.
  2. OPPO N1 Home Button, Volume Buttons and SIM Card Tray Replacement: 2 단계, 이미지 1/2 OPPO N1 Home Button, Volume Buttons and SIM Card Tray Replacement: 2 단계, 이미지 2/2
    • In the photo we rotated the phone ninety degrees counterclockwise.
    • Gently slide the plastic opening tool around the edge of the phone to release the back cover from the phone. You may hear some snapping noises as you release the back cover.
    • The rear case should then come free.
  3. OPPO N1 Home Button, Volume Buttons and SIM Card Tray Replacement, Home Button, Volume Buttons and SIM Card Tray: 3 단계, 이미지 1/1
    • Use tweezers to remove the home button.
  4. OPPO N1 Home Button, Volume Buttons and SIM Card Tray Replacement: 4 단계, 이미지 1/1
    • Use tweezers to remove the volume button.
  5. OPPO N1 Home Button, Volume Buttons and SIM Card Tray Replacement: 5 단계, 이미지 1/2 OPPO N1 Home Button, Volume Buttons and SIM Card Tray Replacement: 5 단계, 이미지 2/2
    • In the first photo we rotated the phone 180 degrees. Use tweezers to remove the SIM card tray.
    • The phone has been rotated in the second picture to show where the buttons are removed from.
    • Our home button is not the original home button and is a replacement piece.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Joshua Stone
회원 가입일: 09/26/14
1,064 평판
안내서 5개 작성하였습니다
USF Tampa, Team 13-5, Staggers Fall 2014 USF Tampa, Team 13-5, Staggers Fall 2014 회원
USFT-STAGGERS-F14S13G5
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 2,516
