주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
소개
Use this guide to replace the rear case on your Oppo N1.
부품
지정된 부품이 없습니다.
  1. Insert the plastic opening tool into the crevice. The back cover is most easily opened by starting at this location.
    • Insert the plastic opening tool into the crevice. The back cover is most easily opened by starting at this location.
  2. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  3. In the photo we rotated the phone ninety degrees counterclockwise. Gently slide the plastic opening tool around the edge of the phone to release the back cover from the phone. You may hear some snapping noises as you release the back cover.
    • In the photo we rotated the phone ninety degrees counterclockwise.
    • Gently slide the plastic opening tool around the edge of the phone to release the back cover from the phone. You may hear some snapping noises as you release the back cover.
    • The rear case should then come free.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Max Pietsch
회원 가입일: 2014년 09월 26일
654 평판
안내서 1개 작성함
USF Tampa, Team 13-5, Staggers Fall 2014 USF Tampa, Team 13-5, Staggers Fall 2014 회원
USFT-STAGGERS-F14S13G5
3 회원들
안내서 8개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 1,333
