주요 콘텐츠로 건너뛰기
OPPO N1 Screen Replacement
필요한 것
  1. OPPO N1 Screen Replacement, Rear Case: 1 단계, 이미지 1/1
    • Insert the plastic opening tool into the crevice. The back cover is most easily opened by starting at this location.
  2. OPPO N1 Screen Replacement: 2 단계, 이미지 1/2 OPPO N1 Screen Replacement: 2 단계, 이미지 2/2
    • In the photo we rotated the phone ninety degrees counterclockwise.
    • Gently slide the plastic opening tool around the edge of the phone to release the back cover from the phone. You may hear some snapping noises as you release the back cover.
    • The rear case should then come free.
  3. OPPO N1 Screen Replacement, Battery: 3 단계, 이미지 1/2 OPPO N1 Screen Replacement, Battery: 3 단계, 이미지 2/2
    • Remove the six 4mm long screws holding the motherboard in with the ph0 Phillips head screw driver.
  4. OPPO N1 Screen Replacement: 4 단계, 이미지 1/1
    • Use the tweezers or your fingers to remove the sliver plates.
  5. OPPO N1 Screen Replacement: 5 단계, 이미지 1/1
    • Remove the black plate with your fingers.
  6. OPPO N1 Screen Replacement: 6 단계, 이미지 1/3 OPPO N1 Screen Replacement: 6 단계, 이미지 2/3 OPPO N1 Screen Replacement: 6 단계, 이미지 3/3
    • Use tweezers or your fingers to pull up the connector tabs.
  7. OPPO N1 Screen Replacement: 7 단계, 이미지 1/2 OPPO N1 Screen Replacement: 7 단계, 이미지 2/2
    • Use the blue opening tool to carefully pry the battery from the sticky tape that attaches it to the device.
  8. OPPO N1 Screen Replacement, Motherboard: 8 단계, 이미지 1/1
    • Use tweezers or fingers to remove the three connector tabs.
  9. OPPO N1 Screen Replacement: 9 단계, 이미지 1/2 OPPO N1 Screen Replacement: 9 단계, 이미지 2/2
    • Use tweezers or your fingers to remove the motherboard.
  10. OPPO N1 Screen Replacement, Headphone Jack and Speaker Cover: 10 단계, 이미지 1/1
    • Remove the two 4mm long screws using the ph0 Phillips head screw driver.
    • Remove the six 3mm long screws using the ph0 Phillips head screw driver.
  11. OPPO N1 Screen Replacement: 11 단계, 이미지 1/2 OPPO N1 Screen Replacement: 11 단계, 이미지 2/2
    • Use tweezers or your fingers to remove the plastic cover.
  12. OPPO N1 Screen Replacement, Screen: 12 단계, 이미지 1/1
    • Use tweezers to disconnect the connector tab.
  13. OPPO N1 Screen Replacement: 13 단계, 이미지 1/1
    • Use tweezers to peel the black strip from the sticky tape attached to the phone so that the black strip will slide through the phone once the screen is removed.
    • Be gentle removing the black strip at this stage. It can easily tear and it must be removed in order to remove the screen.
  14. OPPO N1 Screen Replacement: 14 단계, 이미지 1/3 OPPO N1 Screen Replacement: 14 단계, 이미지 2/3 OPPO N1 Screen Replacement: 14 단계, 이미지 3/3
    • Insert the blue opening tool into the crevice between the screen and the main body of the phone. Gently slide the tool around the edge of the phone.
  15. OPPO N1 Screen Replacement: 15 단계, 이미지 1/2 OPPO N1 Screen Replacement: 15 단계, 이미지 2/2
    • Insert the blue opening tool in between the black screen and the white border and slide it around the edge of the black screen.
결론
다른 10명이 해당 안내서를 완성하였습니다.
Joshua Stone
회원 가입일: 09/26/14
1,064 평판
안내서 5개 작성하였습니다
USF Tampa, Team 13-5, Staggers Fall 2014 USF Tampa, Team 13-5, Staggers Fall 2014 회원
USFT-STAGGERS-F14S13G5
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 7
30일 전: 24
전체 시간: 5,191
