소개
If your SIM card has remained lodged in your device after removing the tray, this guide will show you how to access the stuck SIM card by partially disassembling the device. This disassembly process can also be used to access the main components like the battery and motherboard.
필요한 것
Unscrew 8 side screws (flat 2.4mm or dedicated torx), then 4 rear screws (hex 1.5mm).
다른 4명이 해당 안내서를 완성하였습니다.
