주요 콘텐츠로 건너뛰기
Oculus Rift CV1 Facial Interface Replacement
필요한 것
  1. Oculus Rift CV1 Facial Interface Replacement, Facial Interface: 1 단계, 이미지 1/1
    • Pull firmly from the top of the headset facial interface to remove the foam frame.
  2. Oculus Rift CV1 Facial Interface Replacement: 2 단계, 이미지 1/1
    • Remove the six T3 4mm screws from the top and bottom edges of the case.
  3. Oculus Rift CV1 Facial Interface Replacement: 3 단계, 이미지 1/1
    • Insert the spudger underneath the edge of the lens on the left or right side.
    • Slide the spudger upwards and around the edge of the frame to undo the tabs underneath.
    • Repeat for the other side of the frame.
  4. Oculus Rift CV1 Facial Interface Replacement: 4 단계, 이미지 1/3 Oculus Rift CV1 Facial Interface Replacement: 4 단계, 이미지 2/3 Oculus Rift CV1 Facial Interface Replacement: 4 단계, 이미지 3/3
    • Lift up the frame to see a tab hidden underneath the lycra mesh along the edge of the lens.
    • Pull up on the tab with the spudger.
    • Repeat for the corresponding tab on the other lens.
  5. Oculus Rift CV1 Facial Interface Replacement: 5 단계, 이미지 1/1
    • Lift up on the plastic frame around the lens.
    • Slide a finger around the inside edge, pulling outward from the center of the lens to release the other tabs.
    • Repeat for the frame on the other lens.
  6. Oculus Rift CV1 Facial Interface Replacement: 6 단계, 이미지 1/1
    • Pull up along the outer frame.
    • Remove the facial interface.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Kyle Anderson
회원 가입일: 01/24/19
226 평판
안내서 1개 작성함
Cal Poly, Team S18-G4, White Winter 2019 Cal Poly, Team S18-G4, White Winter 2019 회원
CPSU-WHITE-W19S18G4
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 9
30일 전: 45
전체 시간: 4,640
