주요 콘텐츠로 건너뛰기
Oculus Rift CV1 Headphones Replacement
필요한 것
  1. Oculus Rift CV1 Headphones Replacement, Headphones: 1 단계, 이미지 1/1
    • Loosen the 4mm Flathead screw from the head strap.
    • Repeat for the headphone on the other side.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Jennifer Lai
회원 가입일: 01/24/19
271 평판
안내서 2개 작성하였습니다
Cal Poly, Team S18-G4, White Winter 2019 Cal Poly, Team S18-G4, White Winter 2019 회원
CPSU-WHITE-W19S18G4
3 회원들
안내서 10개 작성하였습니다
댓글 4개
can you do a tear down of these headphones?
Julian Chan - 답글
Please
John D - 답글
A teardown would be very useful please
theSplund - 답글
This is an assembly. Could u please fix the issue of the screw getting loose on the actual ear piece, please. Which goes into having to fix something that is a real headache for most of us. please.
Amaya Hiko - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 25
30일 전: 77
전체 시간: 6,185
