소개
If the lenses are cracked or do not show the visuals correctly, you may want to replace the lenses. You will need a Phillips #00 screwdriver and a spudger for this replacement.
필요한 것
Pull firmly from the top of the headset facial interface to remove the foam frame.
거의 끝나갑니다!
결론
다른 3명이 해당 안내서를 완성하였습니다.
