소개
我们来面对吧,今年是2013年。我们的飞车在哪里? 为什么不深space travel一个事情呢? 为什么没有虚拟现实成为现实? Oculus Rift旨在弥补我们生活中虚拟现实的缺乏。 仍然处于早期发展阶段,Oculus Rift承诺向渴望的公众提供VR游戏。 加入我们,我们在Oculus Rift及其硬件中探寻。
필요한 것
虽然在技术规格方面并不多,但是我们到目前为止已经收集到了:
分辨率为1280 x 800像素,每个眼为640 x 800。
水平视场大于90度。
对角线视场大于110度。
使用1000 Hz绝对9DOF方向传感器(包括陀螺仪,加速度计和磁力计)完成磁头跟踪。
目前只适用于PC。
我们还发现,它有一个很好的例子,它拥有超过十亿条电缆/适配器(我们的专业估计)。
다음 번역가들에게 특별히 감사 드립니다:
100%
笑得像个300斤的孩子님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
댓글 9개
I have a Dell M6400 with only a VGA (female) out, would a DVI adapter work? Any Suggestions?
Are the cables/connections provided female/male? DVI-D, DVI-A, or DVI-I?
You would need something like this:
http://www.datapro.net/products/vga-to-d...
It requires a converter with active electronics; a passive adapter would not work.
A different rev. of the Rift might support analog input, but this one does not appear to have the signals hooked up (based on what I can see, which isn't quite enough).
cityzen -
Thank you for the confirmation cityzen! and for the recommendation.
a digital converter is a pricey addition, do you think a USB2.0 to HDMI adapter (http://www.amazon.com/Sabrent-1920x1080-...) could be a more economical option?
or maybe an ExpressCard or PCMCIA card would provide the necessary bandwidth? But don't see many offerings.
hello -
A USB2.0 adapter would not be suitable for fast-action video. I wouldn't count on the other options, either. You can find cheaper adapters than the one I pointed out, which was just the first I happened to come across. Another example is: http://www.ambery.com/2covivgatodv.html
Actually, looking at the specs for your notebook, you should have a DisplayPort, and you can get a cheap adapter from that to DVI-D.
cityzen -
cityzen, you are a gentleman and a scholar. my thanks go out to you!
hello -
