주요 콘텐츠로 건너뛰기
Oculus Rift DK1 Control Box Bottom Cover Replacement
필요한 것
  1. Oculus Rift DK1 Control Box Bottom Cover Replacement, Control Box Bottom Cover: 1 단계, 이미지 1/3 Oculus Rift DK1 Control Box Bottom Cover Replacement, Control Box Bottom Cover: 1 단계, 이미지 2/3 Oculus Rift DK1 Control Box Bottom Cover Replacement, Control Box Bottom Cover: 1 단계, 이미지 3/3
    • Use a plastic opening tool to carefully pry off the four rubber feet from the control box.
    • You have now revealed the four 9 mm Phillips #1 screws underneath the rubber feet.
  2. Oculus Rift DK1 Control Box Bottom Cover Replacement: 2 단계, 이미지 1/3 Oculus Rift DK1 Control Box Bottom Cover Replacement: 2 단계, 이미지 2/3 Oculus Rift DK1 Control Box Bottom Cover Replacement: 2 단계, 이미지 3/3
    • Use a Phillips #1 Screwdriver to unscrew the four 9mm Phillips screws on the bottom of the control box.
    • You can now remove the bottom lid of the control box. It should come apart easily.
결론
Audrey Chan
회원 가입일: 01/12/15
201 평판
안내서 2개 작성하였습니다
Cal Poly, Team 70-5, Forte Winter 2015 Cal Poly, Team 70-5, Forte Winter 2015 회원
CPSU-FORTE-W15S70G5
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 416
