주요 콘텐츠로 건너뛰기
Oculus Rift Development Kit 2 Headset Motherboard Replacement
필요한 것
  1. Oculus Rift Development Kit 2 Headset Motherboard Replacement, Eye Relief Adjustment Screw: 1 단계, 이미지 1/3 Oculus Rift Development Kit 2 Headset Motherboard Replacement, Eye Relief Adjustment Screw: 1 단계, 이미지 2/3 Oculus Rift Development Kit 2 Headset Motherboard Replacement, Eye Relief Adjustment Screw: 1 단계, 이미지 3/3
    • Remove front cover plate.
    • Unplug the USB and HDMI cables from the Oculus Rift DK2.
  2. Oculus Rift Development Kit 2 Headset Motherboard Replacement: 2 단계, 이미지 1/3 Oculus Rift Development Kit 2 Headset Motherboard Replacement: 2 단계, 이미지 2/3 Oculus Rift Development Kit 2 Headset Motherboard Replacement: 2 단계, 이미지 3/3
    • Remove the four 3/8" Phillips #0 screws from the inner portion of the headset.
  3. Oculus Rift Development Kit 2 Headset Motherboard Replacement: 3 단계, 이미지 1/2 Oculus Rift Development Kit 2 Headset Motherboard Replacement: 3 단계, 이미지 2/2
    • With the screws removed, gently pull the headband frame apart from the headset.
  4. Oculus Rift Development Kit 2 Headset Motherboard Replacement, Remove Lens: 4 단계, 이미지 1/2 Oculus Rift Development Kit 2 Headset Motherboard Replacement, Remove Lens: 4 단계, 이미지 2/2
    • With the Oculus facing up, twist the right lens clockwise and lift it out. Repeat for the left lens twisting counterclockwise instead.
  5. Oculus Rift Development Kit 2 Headset Motherboard Replacement, Headset Motherboard: 5 단계, 이미지 1/1
    • Using tweezers, carefully lift the four rubber plugs as shown. They are a bit snug and you may need to jiggle them free with the tweezers.
  6. Oculus Rift Development Kit 2 Headset Motherboard Replacement: 6 단계, 이미지 1/1
    • Remove the four 3/8" screws attaching the eyewear enclosure to the front casing.
    • Read the next step before removing the faceplate!
  7. Oculus Rift Development Kit 2 Headset Motherboard Replacement: 7 단계, 이미지 1/2 Oculus Rift Development Kit 2 Headset Motherboard Replacement: 7 단계, 이미지 2/2
    • Carefully separate the faceplate and the cover. Gently rest the cover plate on top of the faceplate as shown in the pictures.
    • Do not use excessive force when separating these two pieces. There is a delicate ribbon cable connected to each.
  8. Oculus Rift Development Kit 2 Headset Motherboard Replacement: 8 단계, 이미지 1/2 Oculus Rift Development Kit 2 Headset Motherboard Replacement: 8 단계, 이미지 2/2
    • Gently pull out the small side tabs on the ribbon cable connector as shown to release the cable.
    • Push the tabs away from you, with the headset oriented as pictured. Carefully slide the ribbon cable out.
    • The headset should now be two separate pieces.
  9. Oculus Rift Development Kit 2 Headset Motherboard Replacement: 9 단계, 이미지 1/3 Oculus Rift Development Kit 2 Headset Motherboard Replacement: 9 단계, 이미지 2/3 Oculus Rift Development Kit 2 Headset Motherboard Replacement: 9 단계, 이미지 3/3
    • Unscrew the three 1/4" Phillips #00 screws as pictured and use the tweezers to lift them out.
  10. Oculus Rift Development Kit 2 Headset Motherboard Replacement: 10 단계, 이미지 1/1
    • Lift the tape and gently pry up the video data ribbon cable using the plastic opening tool as shown.
  11. Oculus Rift Development Kit 2 Headset Motherboard Replacement: 11 단계, 이미지 1/3 Oculus Rift Development Kit 2 Headset Motherboard Replacement: 11 단계, 이미지 2/3 Oculus Rift Development Kit 2 Headset Motherboard Replacement: 11 단계, 이미지 3/3
    • Gently pry back the motherboard clips to release the motherboard. The motherboard should now lift free.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Adam
회원 가입일: 01/20/15
625 평판
안내서 4개 작성하였습니다
Cal Poly, Team 18-5, Maness Winter 2015 Cal Poly, Team 18-5, Maness Winter 2015 회원
CPSU-MANESS-W15S18G5
4 회원들
안내서 6개 작성하였습니다
댓글 한 개
hi.
you know where possible buy the new motherboard?
Szatmari Attila - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 2,380
