주요 콘텐츠로 건너뛰기
Office Chair Gas Cylinder Replacement
필요한 것
  1. Office Chair Gas Cylinder Replacement, Gas Cylinder: 1 단계, 이미지 1/1
    • Place the chair horizontally, putting it on its side.
  2. Office Chair Gas Cylinder Replacement: 2 단계, 이미지 1/1
    • The base is connected to the chair either with retaining clips or nuts and bolts at its center.
    • Remove the retaining clips or unscrew the nuts and bolts with a wrench or drill.
    • Remove the base of the chair.
  3. Office Chair Gas Cylinder Replacement: 3 단계, 이미지 1/1
    • Place a pipe wrench on the gas cylinder, and spray it with WD-40 to lubricate it and make it easier to remove.
    • Twist and pull the wrench to loosen the cylinder and remove it from its place.
  4. Office Chair Gas Cylinder Replacement: 4 단계, 이미지 1/1
    • Look up the chair's part number to find which gas cylinders are compatible with your chair.
  5. Office Chair Gas Cylinder Replacement: 5 단계, 이미지 1/1
    • Be sure to follow the instructions for your specific gas cylinder, since installation procedures may vary.
    • Place the tapered part of the cylinder into the column and rotate it into place.
    • Reconnect the base of the chair.
    • Place the chair upright and adjust the chair to your preferred height. Test it out by sitting on it.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
Christian Phillip
회원 가입일: 09/20/20
170 평판
안내서 1개 작성함
York University, Team S1-G4, Woodhouse Fall 2020 York University, Team S1-G4, Woodhouse Fall 2020 회원
YORK-WOODHOUSE-F20S1G4
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 27
30일 전: 150
전체 시간: 10,281
