소개
The X7R Marauder from Olight is a great flashlight. Unfortunately, the batteries are permanently installed and, according to the manufacturer, cannot be replaced by the user.
If your batteries go bad after the warranty has expired, you can use the following steps to replace the batteries in your Olight 7XR flashlight.
필요한 것
The three screws on the side can be loosened by a 0.9mm Allen key.
The cover can then be removed.
Reverse the steps to reassemble your device.
다른 3명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
Andrew S님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
댓글 2개
what size allen key?
what size are the batteries?
ben senise - 답글
The allen key size is H0.9mm
The battery size is 18650.
Andrew S -
