이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Over time, the LCD screen can be damaged. This guide shows the relatively easy process for replacing the display on the Olympus C-765.
필요한 것
Remove all the screws holding the back plate in place. This inclueds:
On the Back: Unscrew the 4mm screw to the right of the viewfinder
On the Bottom:
Unscrew the 3mm screw in the top left corner
Unscrew the four 3mm screws under the battery cover
On the Right Side: Unscrew the one 3mm screw holding the right-side panel.
On the Left Side: Unscrew the two 2mm screws holding the left-side panel.
다른 2명이 해당 안내서를 완성하였습니다.
