주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
We will show how to tear down to and remove the LCD screen.
  1. Unscrew all immediately visible screws on the body of the camera. Locations (# of screws): Bottom of camera (3), left side near video port (2), under cover of USB slot (3), memory card slot (1).
    • Unscrew all immediately visible screws on the body of the camera.
    • Locations (# of screws): Bottom of camera (3), left side near video port (2), under cover of USB slot (3), memory card slot (1).
  2. Use the plastic opening tool to separate the back cover from the camera. Use the plastic opening tool to separate the back cover from the camera. Use the plastic opening tool to separate the back cover from the camera.
    • Use the plastic opening tool to separate the back cover from the camera.
  3. With the back plate off, locate two screws: one diagonal from the top left of the LCD screen and one diagonal from the top right of the LCD screen. Unscrew both of these screws. Unscrew both of these screws.
    • With the back plate off, locate two screws: one diagonal from the top left of the LCD screen and one diagonal from the top right of the LCD screen.
    • Unscrew both of these screws.
  4. OPEN ALL THE TABS
    RAM Upgrade Kits for Mac
    키트 쇼핑하기
    Enough RAM
    For All The Tabs
    키트 쇼핑하기
  5. Flip the LCD screen over.
    • Flip the LCD screen over.
  6. Undo the clip holding the ribbon cable that attaches the LCD screen to the motherboard.
    • Undo the clip holding the ribbon cable that attaches the LCD screen to the motherboard.
  7. Unclip the plug attached to the red and white wires that connects the LCD screen to the motherboard. Unclip the plug attached to the red and white wires that connects the LCD screen to the motherboard.
    • Unclip the plug attached to the red and white wires that connects the LCD screen to the motherboard.
  8. The LCD screen housing should now be free of the camera. The LCD screen housing should now be free of the camera. The LCD screen housing should now be free of the camera.
    • The LCD screen housing should now be free of the camera.
결론
GradStudents2011
회원 가입일: 2011년 09월 08일
21 평판
안내서 3개 작성하였습니다
University of Maine, Team 1-27, Diaz Fall 2011 University of Maine, Team 1-27, Diaz Fall 2011 회원
UMAINE-DIAZ-F11S1G27
1 회원
안내서 3개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 988
