주요 콘텐츠로 건너뛰기
Olympus Camedia D560 Rear Panel Control Buttons Replacement
필요한 것
  1. Olympus Camedia D560 Rear Panel Control Buttons Replacement, Rear Panel Control Buttons: 1 단계, 이미지 1/2 Olympus Camedia D560 Rear Panel Control Buttons Replacement, Rear Panel Control Buttons: 1 단계, 이미지 2/2
    • Before disassembling your camera, be sure it is powered off.
    • Remove two screws from the video port located at the side panel of the camera.
    • Remove three screws from the bottom panel of the camera.
  2. Olympus Camedia D560 Rear Panel Control Buttons Replacement: 2 단계, 이미지 1/2 Olympus Camedia D560 Rear Panel Control Buttons Replacement: 2 단계, 이미지 2/2
    • Open the USB port cover, and remove three screws from inside.
    • Next, open the memory slot cover and remove the screw.
  3. Olympus Camedia D560 Rear Panel Control Buttons Replacement: 3 단계, 이미지 1/3 Olympus Camedia D560 Rear Panel Control Buttons Replacement: 3 단계, 이미지 2/3 Olympus Camedia D560 Rear Panel Control Buttons Replacement: 3 단계, 이미지 3/3
    • Use the blue opening tool to loosen and separate the back cover from the camera.
  4. Olympus Camedia D560 Rear Panel Control Buttons Replacement: 4 단계, 이미지 1/3 Olympus Camedia D560 Rear Panel Control Buttons Replacement: 4 단계, 이미지 2/3 Olympus Camedia D560 Rear Panel Control Buttons Replacement: 4 단계, 이미지 3/3
    • Locate and unscrew the three screws inside the back cover body (picture 3) .
    • Remove button pad assembly from the back cover.
  5. Olympus Camedia D560 Rear Panel Control Buttons Replacement: 5 단계, 이미지 1/3 Olympus Camedia D560 Rear Panel Control Buttons Replacement: 5 단계, 이미지 2/3 Olympus Camedia D560 Rear Panel Control Buttons Replacement: 5 단계, 이미지 3/3
    • The button assembly is now separate from the back cover.
    • Inspect for broken areas. Replace or clean the button parts.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
GradStudents2011
회원 가입일: 09/08/11
21 평판
안내서 3개 작성하였습니다
University of Maine, Team 1-27, Diaz Fall 2011 University of Maine, Team 1-27, Diaz Fall 2011 회원
UMAINE-DIAZ-F11S1G27
1 회원
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 11
30일 전: 16
전체 시간: 1,027
