이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Press and slide the battery cover retainer clip to the left. Use tweezers to lift the battery cover away.
Remove the single screw from the battery housing using a Phillips #00 screwdriver.
To avoid disconnection of the connector line to the motherboard, use caution when pulling faceplate away from camera case.
Using a Phillips #00 screwdriver, remove three screws fastened to the camera backplate edge.
Using a Phillips #00 screwdriver, remove the two camera flash screws secured to either side of bulb housing component.
Using an iFixit opening tool, pry the backplate from the camera internal housing component.
Remove one screw Phillips #00 from the right side of the LCD screen camera internal housing component.
To check that all screws are removed from the exterior side panel, gradually slide and lift no more than 3cm away from the camera internal component body.
View the front of the camera internal housing component.
Using tweezers, detach the gray connector and blue wiring tape.
View the top of the camera internal housing component.
Using tweezers, gently lift the black tape exposing all connector wires.
View the bottom of the camera internal housing component.
Use tweezers to gently wiggle, pull, and detach tape from the surface of the camera internal housing component.
Using tweezers, gently lift the speaker, cautiously maneuvering the wire away from the side of the internal housing component toward the front of the camera internal housing component.
Gently lift the LCD screen away from the camera internal housing component hinging the thick yellow wiring tape attached to the camera internal housing component.
Use a forefinger and thumb to gently pull the thick yellow wiring tape out of the camera internal housing component.
Flip the camera so you are looking at the back.
Looking at the back of the camera, remove the 3 screws behind the camera lens.
Flip the camera so that the front lens is facing up.
Disconnect the lens from the logic board.
Flip the camera back over so that the back of the camera is facing you, and the lens in facing away.
Disconnect the wire that connects the logic board to the lens assembly.
Flip the camera back around so that the front is facing you.
Carefully lift the lens assembly out of the camera.
