소개
This guide will take you through all the steps to sucessfully install a new logic board to your Olympus D590 camera.
부품
부품은 필요하지 않습니다.
  1. Flip camera so you are looking at the bottom.
    • Flip camera so you are looking at the bottom.
    • Unscrew all 5 base plate screws.
  2. Lift open retainer clip by sliding the clip to the left and letting the clip pop up.
    • Lift open retainer clip by sliding the clip to the left and letting the clip pop up.
  3. Unscrew the single screw located next to the battery slot.
    • Unscrew the single screw located next to the battery slot.
  4. Turn the camera so that the USB, AV and DC in/out rubber plate it facing you.
    • Turn the camera so that the USB, AV and DC in/out rubber plate it facing you.
    • Lift the rubber plate exposing the ports beneath.
  5. US$100.00 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  6. Unscrew the 2 screws next to the USB and AC ports.
    • Unscrew the 2 screws next to the USB and AC ports.
  7. Use a flathead screwdriver or another flat opening tool to pry the faceplate from the whole device.
    • Use a flathead screwdriver or another flat opening tool to pry the faceplate from the whole device.
  8. Pull off the faceplate to reveal the inside of the camera.
    • Pull off the faceplate to reveal the inside of the camera.
    • Be careful of the connector that goes from the faceplate to the motherboard . Disconnecting this line will cause the camera not not power on through the on/off switch anymore.
  9. Unscrew all 4 circled screws.
    • Unscrew all 4 circled screws.
  10. The logic board should now be loose and easily liftable.
    • The logic board should now be loose and easily liftable.
    • DO NOT lift the board out completely the wiring that is still connected must be disconnected before proceeding.
  11. Disconnect the 3 wiring strips from the device by gently pulling with tweasers from the base of the strip. Do not use sharp tweasers because the wiring might tear. Make sure to use small force so the wiring is not damaged.  It may help to gently wiggle the tape.
    • Disconnect the 3 wiring strips from the device by gently pulling with tweasers from the base of the strip.
    • Do not use sharp tweasers because the wiring might tear.
    • Make sure to use small force so the wiring is not damaged. It may help to gently wiggle the tape.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Sara
회원 가입일: 2010년 04월 15일
84 평판
안내서 2개 작성하였습니다
Cal Poly, Team 28-23, Regan Spring 2010 Cal Poly, Team 28-23, Regan Spring 2010 회원
CPSU-REGAN-S10S28G23
4 회원들
안내서 7개 작성하였습니다
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 1,612
