주요 콘텐츠로 건너뛰기
Olympus Digital Camera TG-3 Front Case Replacement
필요한 것
  1. Olympus Digital Camera TG-3 Front Case Replacement, Front Case: 1 단계, 이미지 1개 중 1개
    • Locate the strap eyelet side of the camera and use the PH000 screwdriver to remove the two 5.3mm screws that hold the strap.
  2. Olympus Digital Camera TG-3 Front Case Replacement: 2 단계, 이미지 1개 중 1개
    • Locate the side of the camera containing the HDMI port. Use the PH000 screwdriver to remove the 5.4mm screw located on the lower left side below the port.
  3. Olympus Digital Camera TG-3 Front Case Replacement: 3 단계, 이미지 1개 중 1개
    • Using the PH000 screwdriver, remove the 3.8mm screw located inside the HDMI port.
  4. Olympus Digital Camera TG-3 Front Case Replacement: 4 단계, 이미지 1개 중 1개
    • Locate the bottom section of the camera. Using the PH000 screwdriver, remove the two 4mm screws located towards the middle (near the battery compartment).
  5. Olympus Digital Camera TG-3 Front Case Replacement: 5 단계, 이미지 1개 중 1개
    • Now you should be able to remove the front case easily using your hand.
결론
작성자
1다른 기여자 명과 함께
Natalia Morales
회원 가입일: 10/11/16
675 평판
안내서 5개를 작성함
USF Tampa, Team 1-6, Leahy Fall 2016 USF Tampa, Team 1-6, Leahy Fall 2016 회원
USFT-LEAHY-F16S1G6
3 회원들
안내서 10개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 13
전체 시간: 1,150
