주요 콘텐츠로 건너뛰기
Olympus Digital Camera TG-3 Shutter + ON/OFF Buttons Replacement
필요한 것
  1. Olympus Digital Camera TG-3 Shutter + ON/OFF Buttons Replacement, Front Case: 1 단계, 이미지 1개 중 1개
    • Locate the strap eyelet side of the camera and use the PH000 screwdriver to remove the two 5.3mm screws that hold the strap.
  2. Olympus Digital Camera TG-3 Shutter + ON/OFF Buttons Replacement: 2 단계, 이미지 1개 중 1개
    • Locate the side of the camera containing the HDMI port. Use the PH000 screwdriver to remove the 5.4mm screw located on the lower left side below the port.
  3. Olympus Digital Camera TG-3 Shutter + ON/OFF Buttons Replacement: 3 단계, 이미지 1개 중 1개
    • Using the PH000 screwdriver, remove the 3.8mm screw located inside the HDMI port.
  4. Olympus Digital Camera TG-3 Shutter + ON/OFF Buttons Replacement: 4 단계, 이미지 1개 중 1개
    • Locate the bottom section of the camera. Using the PH000 screwdriver, remove the two 4mm screws located towards the middle (near the battery compartment).
  5. Olympus Digital Camera TG-3 Shutter + ON/OFF Buttons Replacement: 5 단계, 이미지 1개 중 1개
    • Now you should be able to remove the front case easily using your hand.
  6. Olympus Digital Camera TG-3 Shutter + ON/OFF Buttons Replacement, Shutter + ON/OFF Buttons Plastic Holder: 6 단계, 이미지 1개 중 1개
    • Locate the strap eyelet side of the camera.
    • Use a PH000 screwdriver to remove the two 5.3 mm screws that secure the strap mount to the front case.
    • Set the screws aside safely, they’ll be needed for reassembly.
  7. Olympus Digital Camera TG-3 Shutter + ON/OFF Buttons Replacement: 7 단계, 이미지 1개 중 1개
    • Turn the camera to the side containing the HDMI port.
    • Using the PH000 screwdriver, remove the 5.4 mm screw located on the lower left below the HDMI port.
  8. Olympus Digital Camera TG-3 Shutter + ON/OFF Buttons Replacement: 8 단계, 이미지 1개 중 1개
    • Open the HDMI port cover. Inside, you’ll find a 3.8 mm screw securing the front case.
    • Use the PH000 screwdriver to remove it carefully.
  9. Olympus Digital Camera TG-3 Shutter + ON/OFF Buttons Replacement: 9 단계, 이미지 1개 중 1개
    • Flip the camera over.
    • On the bottom side, remove the two 4 mm screws near the battery compartment using the PH000 screwdriver.
  10. Olympus Digital Camera TG-3 Shutter + ON/OFF Buttons Replacement: 10 단계, 이미지 1개 중 1개
    • Once all screws are removed, gently lift off the front case by hand.
    • If it feels stuck, double check for any missed screws before applying more pressure.
  11. Olympus Digital Camera TG-3 Shutter + ON/OFF Buttons Replacement: 11 단계, 이미지 1개 중 1개
    • Locate and remove the 7 mm screw in the upper-right corner of the internal frame using the PH000 screwdriver.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Natalia Morales
회원 가입일: 10/11/16
675 평판
안내서 5개를 작성함
USF Tampa, Team 1-6, Leahy Fall 2016 USF Tampa, Team 1-6, Leahy Fall 2016 회원
USFT-LEAHY-F16S1G6
3 회원들
안내서 10개를 작성함
1가이드 댓글
Thanks for the post. Do you know where to buy new switches?
Richard Chesher - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 11
지난 30일: 27
전체 시간: 2,456
